Old 04-03-2018, 12:50 AM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
hub centric ring help
So I picked up some hub centric rings for my TC105N
56.1mm to 73.1mm They dont seem to fit quite right. But I've never installed hub centric rings. I feel like the rings should go into the wheel more then this:
Top down photo:
What do you guys think?
Elliotw is offline   Reply With Quote
Old 04-03-2018, 02:06 AM   #2
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Some hub centric rings are a tight fit, making sure it stays on. You could use a mallet and tap it slightly until it sits flush in the bore.
I've had some which are a loose fit which falls off as soon as u take the wheels off.
Brzerker is offline   Reply With Quote
Old 04-03-2018, 02:10 AM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Top down photo:
Well, if the backside of the wheel does not contact the rotor when installed, then it's not going to work.
Google came up with this among other things.
[ame]https://m.youtube.com/watch?v=j0fWPPNaeM8[/ame]
Also, it might be the picture but that flange looks a bit too big for the countersink.
Old 04-03-2018, 09:48 AM   #4
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The problem is that you have the wrong size hubcentric ring. TC105N in 5x100 have a inner diameter of 65mm. Try rings with 56.1x65
http://nebula.wsimg.com/e9d732f621d5...&alloworigin=1
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 04-03-2018, 10:56 AM   #5
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
What if you need to go the other way? Can the center bore be accurately increased? My winter wheel/tire set up for my 2015 Corolla has a 54.1 center bore, so close to fitting on my 86 with a 56.1 mm bore.
SCQTT is offline   Reply With Quote
Old 04-03-2018, 12:01 PM   #6
Apoc
Apoc's Avatar
It isn't a matter of accuracy it may weaken the wheel.
“The World is Flat”
[||•]=(86)=[•||]
Old 04-03-2018, 12:25 PM   #7
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Yeah, I could see that. I guess I just need to buy another setup or put the car away for winter. This was my first winter with the 86 and I didn't drive it.
Old 04-03-2018, 02:25 PM   #8
Elliotw
Elliotw's Avatar
This must be the problem. I will order the correct set.
Hub centric Ring for 57c6 ikarntspel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-16-2016 09:08 PM
Missing Hub-Centric Ring Apex_BRZ Tracking / Autocross / HPDE / Drifting 7 04-28-2015 02:40 AM
Do I need hub centric ring 07jazzrs5gt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-20-2014 03:56 AM
Is 1mm worth a hub centric ring? swift996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-28-2013 04:00 PM
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-08-2012 12:19 AM
