Old 09-08-2019, 06:57 PM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
"I can't even see if my pads are low. Worst brake design ever."
Well, I don't know bout that -
Back in the day, to inspect the brake shoe thickness, one had to first jack up the car with a flimsy bumper jack, then go find the cement blocks (that your dad used for something else) to put under the car, then find the big star lug nut wrench (that your brother used and didn't put back), then take off the wheel.
Next, pull on the brake drum and see that it is stuck, so go find the BFH (that someone didn't put back in the combine's tool box) then beat on the drum to the point you were afraid you were going to break it. Then if you were lucky, the drum would pop off, exposing you to a face full of finely ground asbestos fibers for you to inhale.
NOW, you can inspect the brake shoes for wear.
Oh, did I mention that, just as you started, it was getting dark and starting to snow and the wind was whipping snow around from both sides of the car?
PS - I left out important step, who knows what it was?
i know of a few cars that the bearing hub is integral to disc assembly. were there any drum brakes that had the bearing hub integral?
because just the thought of having to repack bearings to check pad thickness could keep me up at night..
i'm sure there's a few...
Old 09-08-2019, 07:07 PM   #30
Originally Posted by GrantedTaken View Post
Clueless idiot.
Go to any parking lot, moron, and look at the calipers of any car.
You will clearly see the brake pads
Have looked at the pads of dozens of different cars. The view is no different than these. I am at total loss as to what cars you have been exposed to that have a free view of the pads and why you can't see that the majority are just like these.
Old 09-08-2019, 07:16 PM   #31
Yep, you would be correct, for the front brakes - the bearings have to come out.
I was thinking of the rear brakes. On the higher mileage older cars, the shoes may have warn down the center portion of the drum, leaving a lip on the outer part of the drum. For the drum to come off, especially if the brakes had been adjusted, the adjusting screw mechanism should be screwed to adjust the shoes to more of a closed (inward) position, so the lip on the drum will clear the shoes.
Oh, humfrz - go take a nap - you're flashing back again -
Old 09-08-2019, 07:21 PM   #32
Bluefire98
Drives: 2015 Scion FRS
Jeez wait till this guy learns how to change the spark plugs...
Bluefire98 is offline   Reply With Quote
Old 09-08-2019, 07:27 PM   #33
soundman98
soundman98's Avatar
^oh, don't remind me!
my neighbor just did rear drum brakes on his wife's hyundai suv. he's a heavy equipment service guy, so he figured a 4 hour job. the previous owner screwed up the adjuster, it took him a day and a half just to get the one drum off!
Old 09-09-2019, 10:19 PM   #34
GrantedTaken
Brakes. Buy from dealer? What else to replace?
At 50k, I'm going to replace my pads and rotors.
I don't want racing crap for basic street driving.
What are my options besides dealer prices?
$85 for a rotor is more than I've ever paid for any car ever.
Besides the pads and rotors,
are there any little parts and extras I should also buy?
GrantedTaken is offline   Reply With Quote
Old 09-09-2019, 11:09 PM   #35
JoeC
Drives: Subaru BRZ Limited
So after all this, do you even know if you need to replace them? It's hard for me to imagine that the pads or rotors need to be replaced at 50k. Maybe the rotors if they've seen a bunch of track use but this thread wouldn't exist if that was the case...
JoeC is offline   Reply With Quote
Old 09-09-2019, 11:11 PM   #36
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Don't forget to install the new calipers which allow you to see the pads clearly without removing the wheels.
MS, CSCS, TSAC-F, CPT
Old 09-10-2019, 03:29 AM   #37
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
You can feel it when you drive it.
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
Old 09-10-2019, 03:31 AM   #38
Impureclient
Drives: 2015 FR-S
You better not, that's probably a felony if you are caught in the act!
Old 09-10-2019, 02:54 PM   #39
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
patience
HKz is offline   Reply With Quote
Old 09-10-2019, 05:03 PM   #40
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
This thread has reminded me I should probably pull my fronts apart and service them.
Old 09-10-2019, 06:20 PM   #41
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
When you can hear you brakes consistently squeal, take off wheels and swing open the rotors to check pads.
Heres a tip for anyone who has yet to change their rotors on their twin. You need a certain size bolt to get the rotors off this car if it is seized up, " if your over 60k on oem rotors chances are its seized. Do yourself a favor and next time you go to the hardware store get two of these bolts. When it comes to take off your rotors you will be very thankful.
DandoX is offline   Reply With Quote
Old 09-10-2019, 06:33 PM   #42
GrantedTaken
I posted a photo in post #17.
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
