Old 08-17-2019, 07:58 PM   #365
Tgutz21
Originally Posted by mswbrz View Post
God damn bro , that's some shit right there I'm truly sorry and hope you had at least a back up car which sounds like you do since you don't drive yours often like myself . What dealer is this ? They going to charge you again for the third engine ? Same tech did the fuck up 2x?
Yes. The same tech. It’s Modesto Subaru in california. Honestly still kinda scared to drive the car. I feel like it’s a ticking time bomb. I didn’t pay anything since since it was clearly a workmanship issue. The only money I gave them was to replace my clutch since they were already pulling the engine anyway.
Tgutz21 is offline   Reply With Quote
Old 08-17-2019, 08:51 PM   #366
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Bro !! That is where I got my recall done !!! I live in Modesto , dm me man so perhaps I can get your number.
mswbrz is offline   Reply With Quote
Old 08-20-2019, 04:44 PM   #367
69gtojeff
Drives: 2013 FR-S 6MT Ultramarine
Vehicle Mileage: 69,000 miles
Vehicle Make: 2013 FR-S MT
Mileage After Recall Performed: 0
Symptom(s): "abnormal noise" during test drive
Failure: rod bearing on cylinder #1 scorched, metal got to the cam bearings
State: WI
Is Dealership Offering Repair: yes, short block and heads that they have to assemble
69gtojeff is offline   Reply With Quote
Old 09-14-2019, 05:04 PM   #368
NannerpussPRO
So I got my car back.
I’ll post exactly what they fixed/repaired but long story short the dealership said the problem was the exhaust valve clearance. They replaced the shims and that supposedly fixed my error. I’m out of town at a wedding and I did not have enough faith in the car to drive it the 300 some miles to the venue so I took my 2011 Milan instead (fast approaching 100K). I’ll try to get some (local) miles on it over the next month or two and see if anything else pops up.
This was my fear— that I’d get the car back but be nervous about it. Now I’m trying to decide if I sell it while it’s in working condition and let someone else deal with the uncertainty.
NannerpussPRO is offline   Reply With Quote
Old 09-19-2019, 08:27 AM   #369
gravitylover
I'm not feeling too good about the warm start rattly clanky noise coming from under the hood. It could be as simple as an exhaust bolt loosened up but it sounds internal. I can almost consistently replicate it by parking with the nose slightly up rather than flat or down. I'm going to go in this morning and see if I can get the tech that did the work come out and listen to it.
Where is the oil pickup in the pan, towards the front or rear, center or off center? If it's partially blocked the motor would be starved on startup right?
Old 09-19-2019, 08:52 AM   #370
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Slightly towards the passenger side, just about in the middle/a little towards the back.
Pictures for reference...
https://www.aliexpress.com/item/32451891516.html
https://www.counterspacegarage.com/bm-oil-baffle-fa20
https://www.aj-racing.com/?product=r...ion-frs-13-zn6
https://www.xero-limit.com/bluemoon-fa20-baffle.html
Joon525 is offline   Reply With Quote
Old 09-20-2019, 02:46 PM   #371
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just received the following from @DJ72 . I don't know the context, conditions, scope, affiliation, or intention of the information I'm relaying in my post here. I'll ask that he reply with more info-
"My 2013 FRS with just 17,000 miles was just diagnosed with engine failure. There is a class action suit that is being put together by the law firm Carlson Lynch. Every case of engine failure had to do with oil starvation, which was a result of the JO2 recall. Please share this info with the board. I can’t figure out how to post it.
carlsonlynch.com
412-322-9243
Dave"
Old 09-22-2019, 08:54 PM   #372
Gunman
Drives: 2019 Mazda Miata RF
https://carlsonlynch.com/scion-subar...ction-lawsuit/
Old 10-14-2019, 07:59 PM   #373
agmendoza
agmendoza's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by Gunman View Post
Been trying to get a hold of them, with no luck. Took my car 3 weeks ago and within 40 miles had complete engine failure. Trying to charge me 14k to fix.
agmendoza is offline   Reply With Quote
Old 10-15-2019, 12:50 PM   #374
Gunman
Personal opinion, you'll be better off not going the class action route.
Old 10-15-2019, 07:27 PM   #375
Snake
Drives: ADM Toyota 86 GT
How are they trying to pin that on you?
Snake is offline   Reply With Quote
Old 10-16-2019, 07:50 PM   #376
agmendoza
agmendoza's Avatar
They are saying that somehow within 40 miles after I drove it off that I did something to cause my rod bearing to go missing and another to get worn out. When I left the dealership the paper work showed no signs of problems in the oil 3 days later they found metal shavings.
Old 10-16-2019, 07:51 PM   #377
agmendoza
agmendoza's Avatar
Why is that?
Old 10-17-2019, 12:29 PM   #378
RickyBobby
Drives: 2013 Firestorm FR-S AT
Why is that?
Read the cons, especially the fact that "if the plaintiffs fail to win the case, they will no longer be able to file new or individual lawsuits over the same issue against the same defendant."
https://margarianlaw.com/class-actio...uit-pros-cons/
Also take the time to read the last 10 pages of the Discussion thread. http://www.ft86club.com/forums/showthread.php?t=133306
RickyBobby is offline   Reply With Quote
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-19-2019 12:24 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 07:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 08:23 PM
