Old 12-06-2019, 10:55 AM   #225
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Chuckls View Post
No worries Eric. Take your time. Gives me a reason to come up and see the Supra
You're welcome anytime. Supra isn't much to look at right now; but hopefully, that is changing this winter !
Here are some CAD images of the rear louvers. I ended up adding some design flair to them.
VerusEric is offline   Reply With Quote
Old 12-06-2019, 05:58 PM   #226
Chuckls
Moutain Runner
Chuckls is offline   Reply With Quote
Old 12-06-2019, 06:58 PM   #227
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
What is the size difference from you large vents? Other than a slight scallop on the aft side looks almost identical to them.
Old 12-08-2019, 08:23 PM   #228
VerusEric
VerusEric's Avatar
They are very similar in size; basically identical in overalls.
Old 12-13-2019, 12:34 AM   #229
jflogerzi
jflogerzi's Avatar
I would be interested in the s550 ones. Do they include/support rain guards?
2013 Series 10 FRS #553
Old 12-18-2019, 04:07 PM   #230
VerusEric
VerusEric's Avatar
The regular S550 Mustang louvers have rain guards available. The GT Spec (larger) do not.
Old 12-18-2019, 05:50 PM   #231
jflogerzi
jflogerzi's Avatar
due to where they are positioned, do you need to cut into the hood structure vs the 4 smaller ones that sit in-between. I admit really like the look of the S550 GT spec on our cars.
Old 12-18-2019, 05:59 PM   #232
VerusEric
VerusEric's Avatar
Yes! To my knowledge, we are the only ones who have louvers for the car that require no cutting of the hood structure. We basically make use of the vast majority of the hood skin; you would be hard-pressed to get larger louvers in the hood without cutting structure away.
[ame]https://www.youtube.com/watch?v=2DONfLNWghU[/ame]
Here is a video of the GT-Spec units going in Clay's car.
Old 12-18-2019, 06:45 PM   #233
churchx
churchx's Avatar
Drives: 2014 GT86
VerusEric: i wonder how much (if cut few ribs) that structure is important, and to what extent cutting it reduces rigidity of hood, and if it's worth or not to think of some additional strenghtening in some way (eg. installing something across/behind louvers, to restore/add rigidity), if large vents are installed? Or maybe large vents should be designed in way, that at places where they cut across ribs, there is some extra material/brace/something alike?
Old 12-18-2019, 06:51 PM   #234
jflogerzi
jflogerzi's Avatar
in that video. Do you guys have the measurements that were used so I can replicate the exact placement.
Old 12-19-2019, 01:12 PM   #235
VerusEric
VerusEric's Avatar
I honestly cannot answer any of those questions. I have no idea. OE designed the underhood structure to crumple in a specific way and modifying that underhood structure likely changes how it will act in a crash.
I'm sure Clay can get you some measurements if you need some. It took us about 4 hours to do; mostly because Clay was nervous. Double and triple check the measurements and you should be golden .
Old 01-30-2020, 11:23 PM   #236
Chuckls
Moutain Runner
Any updates?
Old 01-31-2020, 06:27 AM   #237
VerusEric
VerusEric's Avatar
Any updates?
They are at powder coating now. If interested in raw, we have them available.
Old 01-31-2020, 02:18 PM   #238
Chuckls
Moutain Runner
Radical. I told Ian about these last night and he would be willing to help get a group buy if you need X amount of people before offering them.
Verus Engineering Brake Cooling Kit VerusEric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 07-15-2023 11:18 PM
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 08:40 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 02:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
