Old 04-24-2020, 05:10 PM   #29
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
it goes from startup and initial idle at 15k, drops to standard idle which is a bit erratic, then to 2k, two accelerator spikes, then up to 3k
snowtaipan is offline   Reply With Quote
Old 04-24-2020, 05:33 PM   #30
snowtaipan
snowtaipan's Avatar
https://datazap.me/u/jirace/v7-85mm-...og=0&data=8-29
Something like this is easier to see, but I don't see anything in boost from your upload. Was this log with you just idling the car and revving it?
Is that an erratic idle?
https://datazap.me/u/snowtaipan/ecut...log=0&data=3-7
Tell me if I'm wrong, the MAP should be the SC PSI right? cause thats low AF
4PSI at 3k RPM??
Old 04-24-2020, 05:59 PM   #31
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
4PSI at 3k RPM??
That looks like you were idling then revved it a little based on the throttle angle/accelerator %.
You never saw any boost. Boost is anything above atmospheric, so higher than 1 bar. You were in vacuum only.
Compare it to mine.
Old 04-24-2020, 06:14 PM   #32
snowtaipan
snowtaipan's Avatar
I'm going to smoke it from my bypass valve to the back of the SC, that's gotta tell me something
Old 04-24-2020, 07:48 PM   #33
Irace86.2.0
Any chance your bypass valve is sticking?
Old 04-24-2020, 09:02 PM   #34
tomm.brz
Drives: brz 2017 hksv2
the log is almost to see but not enough to judge.. , it s not erratic idle, you can see him blipping
It s strange, to me sounds like vacuum leak but i would need to see a longer log, with actually driving
just a few second cold start where most of the time the Ecu forces 50/50% DI/PI isn t ideal
Also strange the values sensed by the MAP, not sure why though
Need more info... has this tune/car ever driven ok before? is the problem come out just lately? who tuned it and have you asked him?
Old 04-24-2020, 09:54 PM   #35
snowtaipan
snowtaipan's Avatar
So I was just digging into the BPV. I noticed when my wife started the car and did a pull on it that the BPV was open, at least partially, the whole time. So in theory I would be low on boost. I'm just not sure a) is it actually malfunctioning and if it is malfunctioning weather b) the spring is week and it opens to easy or c) something other than the BPV is bad and pulling a tone of vacuum
Old 04-24-2020, 09:59 PM   #36
snowtaipan
snowtaipan's Avatar
I'm uncomfortable doing and actual drive, and my POS laptop can't be counted on without a wall plug
I'm starting to suspect the BPV wasn't calibrated correctly. OR somethings pulling way too much vacuum on it, cause it opens at startup and basically stays wide open
No, this issue was present immediately after install. The tune came direct from Edelbrock, it's a CARB legal plug and play set for a bone stock car, which mine was
Old 04-24-2020, 10:12 PM   #37
snowtaipan
snowtaipan's Avatar
So I smoked the BPV to the SC, smokes out the TB
Smoked the right side PCV, smokes out the TB
Sooooo i capped the TB and ran probably 10lbs of smoke from the left side PCV. didn't go anywhere. No leaks. WTF. That should pressurize the entire system. I could see the plastic over the TB bulging.
I'm pretty sure it's not a vacuum leak, unless I should't be getting it coming back to the TB.
https://datazap.me/u/snowtaipan/2017...=0&data=3-7-23
So my thought is, the BPV is opening to easy, so a tiny bit of vacuum and she vents boost. The TMAP sensor sees not enough pressure.. yeah my brain's dead.
Old 04-24-2020, 10:13 PM   #38
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Do you have a vaccum pump, like a MityVac? Testing the bypass valve with one is best way to determine if it is functioning properly. I have the old style bypass valve and here are some notes I took when I was having a problem with a leak.
Bypass valve ops
vacuum = open, bypassing SC compressed air
no Vacuum (car off, resting condition) or during boost = closed, using SC compressed air
tested with vacuum pump and it begins to open (pull in) at ~5in/Hg (-2.5 psi) and is fully open at ~10 in/Hg (-5 psi) and should hold
Edit 2
***Just checked with it on the car and it was ~6in/Hg started to pull in and ~12in/Hg fully opened***
BirdTRD is offline   Reply With Quote
Old 04-25-2020, 12:09 AM   #39
Irace86.2.0
Like it’s been said, off throttle equals vacuum equals open valve. On throttle equals boost equals closed valve.
Old 04-25-2020, 02:03 AM   #40
Irace86.2.0
I wouldn’t want to jump to any conclusions. It is fairly short duration. Any problems on your end?
Warm up the engine. Try logging a 3-5 minute idle. Then do a separate 2k hold for 2 minutes then do a 3k hold for two minutes. Post those three datalogs. Post comments about your impressions on each.
Old 04-25-2020, 01:56 PM   #41
BirdTRD
Simply Forgotus
BirdTRD's Avatar
"I'm starting to suspect the BPV wasn't calibrated correctly. OR somethings pulling way too much vacuum on it, cause it opens at startup and basically stays wide open"
This is normal behavior. Vacuum at idle is (or should be) more than enough to pull the valve fully open and hold it there, allowing uncompressed air to bypass the SC rotors.
When my valves diaphragm had a tear in it, there was still enough vacuum to open it and hold it open at idle so the valve appeared to behave normally. However, due to that tear, I now had a vacuum leak which gave me the same symptoms you're seeing right now.
Old 04-25-2020, 05:37 PM   #42
snowtaipan
snowtaipan's Avatar
Unhappy
So I rechecked hoses, wires, clamps etc.
Re flashed the ECU for I think the 5th time
Started logging before I cranked it
Idled until LTFT stabilized (Again around 35-40)
Held at 2k RPM for 1 minute
Held at 3k RPM for 1 minute
held at idle.
I'm uncomfortable doing any more logging with the trim that high, so if we can work with what we got great, if not I don't know what to do but I'm worried I'm going to break something beyond whatever the current issue is.
I do see that as the fuel learn creeps up with the LTFT, there's no real issue with the AFR. It's slightly high, but not at like 19 or something. Also shouldn't MAF voltage spike when I open throttle, and shouldn't MAF g/s be higher?
https://datazap.me/u/snowtaipan/fina...zoom=1338-1484
edelbrock, p0171, p117b, supercharger
P015A, P015B, P0171, P117B and P0170. kev0 Issues | Warranty | Recalls / TSB 5 08-21-2019 02:30 PM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 09:03 PM
P1170 P117B Direct Injection Issue? gonzo Issues | Warranty | Recalls / TSB 4 01-11-2017 03:23 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 03:50 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 05:23 PM
