#253 |
Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Gonna bump this up to the top as I see many more people are running this header out in the wild! How are y'all enjoying it? I was planning a local dyno day earlier this year to compare the gains vs a stock vehicle on the same dyno/same day to have more data for everyone, but due to COVID that obviously couldn't happen.
I still wholeheartedly recommend this header if you're looking for an EL option. My car is still sounding and driving awesome. Hope everyone is staying safe!
#254 |
Drives: '14 FRS TT5
I don't recall if I posted my dyno numbers after I went to E85, but here are my numbers.
You'll probably say, "these look low!" and "there's no comparison!", which are both accurate statements. But the one constant here is that these dyno runs were conducted in compliance with NASA's dyno testing procedures, which usually read low. ![]() Also, the only sounds you need are at full throttle
Follow my NASA TT5 build here: JHill Motorsports
#255 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#256 |
Good Job Subaru!
I also have the same G spot on my dyno run That’s where vtak kicks in.
#257 | |
"looking at the torque cure, you packin some long tubes" know what I'm sayn'? ![]() Edit: *crickets*
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 06-09-2020 at 06:32 PM. |
#258 |
Just do it. Beside the ace350's these are fantastic headers. Love them with my boosted twin. And they are cheaper to boot than the ace headers
2013 Series 10 FRS #553
#259 |
Drives: Subaru BRZ
Nevermind the numbers, with ACE headers peak hp is usually around 7,400 rpm and the tq stays flat until around 7,000 rpm (my dyno sheet). Can JDL achieve that, or are you limited by class rules and had to detune at higher rpms?
#260 | |
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 06-12-2020 at 12:52 AM. |
#262 |
Here is my Dyno pull with Zach at csg
https://www.instagram.com/p/B8sJ1XDn...d=ty42p88y5tfo https://www.instagram.com/p/B8sOU-0n...d=klqnb0pf9upg Sprintex 210 +69mm pulley IC, flex fuel JDL 4-2-1, stock op/fp with extra ultra vibrant resonator and mxp sp exhaust Sent from my GM1915 using Tapatalk
#264 |
IT is odd that the torqu tapers off sharply on that dyno. Maybe timing is being pulled at 6400rpms.
Intent > Content
#265 | |
Good Job Subaru!
JDL 4-2-1 EL header
It’s certainly possible. For reference; here’s my dyno from earlier in the thread. Unfortunately this was only a 7100rpm run but the torque holds on pretty well, with a slight taper past 6750 but not as steep of a fall-off. ![]() OnPoint Dyno’s Dynapack reads very similarly to the CSG Dynapack (that is to say, low) based on the numbers I’ve seen from both.
#266 | |||
Drives: '14 FRS TT5
And yes, I'm still on the same exhaust setup (JDL 4-2-1 EL header, JDL overpipe, JDL catless frontpipe w/ single resonator, Tanabe Concept G catback). Might need to follow up with my tuner on that. Quote:
OEM brakes, Carbotech XP12 pads in the front, XP8 in the rear. I don't see a reason to upgrade brakes on this car other than reducing consumables. I am on Hoosier R7's as well, so that helps too
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 03:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
