#15 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#16 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
Interesting thought. I forget what color they made them but if they're black or silver maybe it will sneak by. Its not like you're modifying the intake since the Power Blocks are on the engine side of the throttle body... maybe I'm just being wishful there.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#17 |
Original 2013 Owner
TLDR: After replacing hardware and reflashing back to stock your car wont be immediately ready to smog. You'll need to drive around normally for a week or so to ensure all your sensors are re-activated.
I switched back to stock hardware and reflashed to the OEM tune. Drove out for 20 or so miles and then took the car to the smog shop. The pre-check showed the Oxygen Sensor, Catalytic Converter sensor, and Evap system were not yet active. ![]() At the shop's recommendation, I took a drive out for 100 or so miles up in the hills. Upon my return, the O2 and Cat sensors had activated and were showing green, but the Evap sensor was not yet active. The shop said to let the car cool completely and before starting the next day, open up the fuel cap for 10 seconds and then close, before starting the car. Apparently this helps reset the Evap sensor. Otherwise, all I have to do is drive the car for about a week before the final sensor is good to go.
φφκα |
#18 |
Drives: Toyota Supra 2JZGTE VVTi
The EVAP usually you need to run like half a tank of gas thru the car to get them to clear. The fuel levels and air temp need to be right to get EVAP to clear.
#19 |
Original 2013 Owner
Passed my smog but I am completely stock so this isn't a surprise.
What I found was that passing visual is 100% up to the tech's effort. He didn't look under my car, and he only gave my engine bay a glance. When I smogged an S2k a few years ago, I recalled that the smog tech was referencing exhaust images seemingly provided from the DMV on the computer, as the car was plugged in. One thing I noticed is the tech references two OEM stickers. One on the drivers door sill which he scans the barcode for quick vehicle details, and one that he needs to reference on the underside of the hood. Those of you with aftermarket hoods may not have that sticker and if he can't reference it, I'm not sure where the tech will get that information.
φφκα Last edited by Cjymiller; 02-23-2021 at 09:28 PM. |
#20 | ||
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I told him everything I pulled off the car for the test and asked what I could have left on and still passed and he said "none of it", lol. Now I'm pretty sure some of it was okay according to CARB appendix G or whatever it is but in the end it's probably less of a headache to just pull everything off than try to argue about it. ¯\_(ツ)_/¯ |
#21 | |
Drives: Q5 + BRZ + M796
#22 | |
#23 | |
Drives: 2013 FR-S Whiteout 5AD
I thought about doing that originally but it was only a couple more bolts to pull the whole thing out. I would think it would be fine since it's not hook up to anything. |
#24 |
Senior gif poster
Drives: 2013 Asphalt FRS
So a catback like the one from Perrin should be okay right? (with no other modifications)
Are all of the twins being heavily inspected? Mine has a pretty stock look aside form wheels and the perrin 2.5 catback, a quick plug and check is what I want. I'm going to have to get mine smogged in June |
#25 | |
#26 | |
Drives: 2013 brz limited / galaxy blue
But weren’t you flapping your gums about how you knew someone that helps with hot smogs q(●‿●)p but your going this route ? U Must be a broke bish to not want to pay your boy to do the hot smog or you just wanting to throw shade. Stay in your lane primo. Sent from my iPhone using Tapatalk |
#27 | |
Maybe don't be a **** next time and you'll have better results. |
#28 |
How bout you stop being a bitch, and help someone out instead of just bragging you know someone but yet you won’t use them yourself . Fuck off man .
| California Smog Check | Phantobe | Southern California | 144 | 06-20-2025 05:16 PM |
| California owners : smog question | Adam_L | Engine, Exhaust, Transmission | 5 | 10-14-2016 12:47 PM |
| Need advice on passing smog in California | rmak321 | Northern California | 7 | 07-12-2014 01:52 AM |
| SMOG Issues | SkullWorks | Engine, Exhaust, Transmission | 8 | 10-04-2012 02:23 PM |
