#29 |
Drives: 2022 GR86
Got the yellow B-M4 kit for my Neptune Blue GR86.
First impressions: looks really good in yellow, strong Poorsche vibes. ![]() The thing is MASSIVE, the photo don't do it justice. Doesn't fit into a spare wheel that came with my Performance Package BRZ. ![]() ![]() Two large gaps between the caliper and the knuckle, should allow more airflow into the rotor than PP Brembos: ![]() Changing pads is a massive pain in the neck. You need to take the caliper off, that bad boy is heavy, and the massive "wing" at the top of the caliper makes it harder to just hang it off a metal hook or something like that. But before you take the caliper off, you need to break the slide pins loose: ![]() You have to use a punch and a hammer to mover the slide pins out, can't just use pliers like I could with PP Brembos. The spring clip is very stiff, and my fingers got really tired as I was trying to pull them the first time. Didn't get much easier the second time. Maybe I'm doing something wrong, but my initial impression is that it's a bad choice for someone who would want to swap the pads frequently. Also, the calipers got really dirty after I changed the pads. It was so much easier with PP Brembos!.. The kit comes with stainless steel brake lines that that have a rubber bracket to hold it against the strut: ![]() The brake line can slide with little resistance up and down that rubber bracket, so if you're really unlucky the brake line might start rubbing against the wheel. I guess I'll be checking the brake line position during each wheel change. That's a strange design, tbh. Curious if anyone was able to use PP Brembo rubber lines instead?
Follow the build thread for my GR86!
#30 |
Drives: 2022 GR86
And yes, it only has one bleed screw per caliper
#31 | |
Drives: Supra MKV, FR-S
#32 | |
IMO, the Spiegler lines are superior, but they also are like 2.5x the price. Yes, you can use factory brake lines if you wish. |
#33 | ||
Drives: 2013 WRB BRZ 6MT
There is some competing information regarding pad swaps with the BM4 in this thread:
So does the whole caliper need to come off to swap pads or not? Maybe @CSG_Mike can clarify? If pad swaps are no more difficult using the BM4 than the standard caliper, the extra $100 for the BM4 is really compelling but as someone who swaps pads at every track day, having to fiddle so much would get old fast. |
#34 | ||
Drives: 2022 GR86
The solid "bridge" on the outside of the caliper surely made it look like I have to remove the caliper; and that was confirmed to me by one of the suppliers. But also when I tried to wiggle the spring clip out of the caliper the diagonal shape of that bridge came in very handy, so there might be a similar clever way to get the pads out.
#35 |
#36 | |
Drives: 2022 GR86
#37 | |
@timurrrr how'd the setup feel compared to your old PP? |
#38 | |
Drives: 2022 GR86
BTW here's how the front rotors looked like after the first track day. CSG C1 in the front. ![]()
#39 |
Drives: 2023 BRZ
The pad deposition looks inconsistent to me. Any idea why?
Director of Rocky Mountain 86CUP
#40 |
The splotchiness is from ABS.
@timurrrr do you have wheel speed and brake pressure traces? Also it looks like you didn't get the Zinc layer off the rotor faces before going ham, so there's some gnarly interactions going on. |
#41 | ||
Drives: 2022 GR86
I only had the car assembled a couple of days before the track day, and had very little time to set up data logging. I ended up missing my first session because my old Braille battery died while I was sanity checking my data setup with the engine off ![]() I can tell from the feel and the sound that I heard that I was indeed engaging ABS more often than I should have. "I have a lead foot". Quote:
(I didn't just slap the kit on and went to the track) Unfortunately I didn't take all the photos I could, but here's a segment of one of the rotors ~40 minutes driving time before I put the C1 pads in: ![]() The high spot was removed by lightly touching it with a screwdriver.
#42 |
The base pads, along with light street driving, won't be terribly abrasive. Your photo says it all! Mixing any transfer from the street pad with the C1 will also have mixed results. Contaminated transfer will yield lower friction and... weird interactions
If you know you are touching ABS, but you're also 'giving it more pedal effort', wouldn't you say that's a bit self-defeating? Get the C1 really, REALLY hot, without ABS use, to burnish them. |
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 03:50 PM |
| WTB: Rear Brembo STI caliper. | grostoine | Want-To-Buy Requests | 2 | 07-16-2014 06:26 PM |
| STI Brembo caliper mounting bolts... | SkAsphalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-13-2014 08:24 PM |
| The price of one Brembo Caliper. | chuttney1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-18-2013 05:32 PM |
