Old 08-15-2026, 10:45 AM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
This might be useful information since there isn't a lot of info on JXB carrier bearing for this platform.
I have a JXB upgraded driveshaft I just pulled off my 2017, replaced it with a stock one from a 2018. My car is up to 130k miles; I ran JXB for maybe 15k miles with their softer street bushing. I have never felt a one piece driveshaft but I imagine this is similar to how one would feel. This isn't a critique of the JXB probably more driveshaft mods in general and how it compliments other bushings.
I also have RCE poly subframe inserts, TRD engine/trans mount and whiteline diff insert with this installed. JXB removed white a bit of lash in the driveline, I started to dislike it day to day as it makes smooth shifting in traffic harder if my foot work isn't perfect. I won't fault the JXB, I suspect there's a bushing combo that would compliment it nicely but decided to unmodify the car a bit to be more livable. Might be useful info for you given you have similar bushings mods as me.
Old 08-22-2026, 10:54 PM   #16
twistednoble
twistednoble's Avatar
Drives: 2015 BRZ Limited
Thanks for the ride report. I have the opposite problem where the shifting is super easy because there's a fairly large zone where the shift will go but then I have to be super gradual with feeding back in the power or I'll get a lurch as it takes up the slop.
Would you be interested in selling the cast off JXB to me? It's really the last bit of potential slop before I have to accept that it must be the differential.
twistednoble is offline   Reply With Quote
Old 08-25-2026, 08:46 AM   #17
RToyo86
RToyo86's Avatar
Thumbs down
I'd consider it, with cross border shipping it's a bit of a nightmare at the moment.
Selling the driveshaft at a whole unit. It can be divorced for shipping. PM if interested
Old 08-25-2026, 01:38 PM   #18
StraightOuttaCanadaEh
Wes
I found that for drivetrain lash the only thing that helped was the front and rear bushing combo for the diff from whiteline. Getting one piece driveshaft helped with the clack-clackery after shifting. Perrin trans mount will eliminate it almost completely, especially when paired with the perrin solid engine mounts, but the NVH is insane, basically race car.
Instagram: @gt86ws
Old 08-25-2026, 11:57 PM   #19
twistednoble
Already done that and it's either worn out or not the issue. New whiteline diff bushings, new TRD mounts. Doesn't feel tight like it did at 40k with whiteline inserts, subframe inserts, and OE trans mount.
Old 08-26-2026, 12:41 PM   #20
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you look into the "critical speed" for your one piece drive shaft?
Old 08-26-2026, 10:24 PM   #21
Wes
Nope. But I had both aluminum and CF ones and prefer the CF is all I know.
Instagram: @gt86ws
Old 08-27-2026, 07:58 PM   #22
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I definitely like how the carbon fiber driveshaft feels when shifting quickly
Old 08-28-2026, 05:17 PM   #23
Wes
For me personally the alu was louder and also vibrated like crazy at 90+ mph. Tried all 4 mounting positions and it made no difference. Looked into getting it balanced but couldn't find a place so I just replaced it with the carbon
Instagram: @gt86ws
My 'Sloppy Stage 2' 4.8 swap FRS Chickeneatman Engine Swaps 3 08-17-2020 10:36 AM
KW coilover boxing sloppy? Ranran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 02-17-2020 10:34 AM
Lug nuts have a sloppy fit in 19mm socket. pcguru2000 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-31-2018 02:13 PM
Shifter is obnoxiously sloppy Takumidesh Engine, Exhaust, Transmission 14 04-25-2017 03:58 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 03:11 PM
