Drives: Asphalt FRS
Auto Trans paddle shift issue
Car has roughly 800 miles on it, was cruising not using paddle shifters doing ~80 mph. Got off the highway and decided to swap over to manual for a bit on the back roads to have a bit of fun. Shifting around 2800rpm eventually hitting 6th gear at around 60mph. Problem is I found myself stuck at 60 unable to accelerate further, I didn't completely open up the throttle but I did put a decent amount of pressure down without seeing any response from the car. It felt as if I had no more power left. Swapped the car back into automatic and immediately felt the Horsepower kick in.
Am I shifting too early? I'll be driving home again on the highway and will try shifting nearer to 4000 rpm. I'm going to the dealership on monday to have lojack installed along. I'll be bringing it to their attention either way, but I wanted to see if this is a known issue or I'm the only one. |
#2 |
Drives: WRB BRZ Limited (AT)
When you put it back into D it probably downshifted. 6th is great for fuel-efficient cruising but is terrible to try an accelerate in especially at 60 or above. At freeway speeds I'll typically drop down to 4th for passing or any kind of quick increase in speed.
Gear ratios for AT below. 6th is pretty weak - it's there for fuel economy, not power. 1st - 3.538 2nd - 2.060 3rd - 1.404 4th - 1.000 5th - 0.713 6th - 0.582 |
#3 |
Drives: @redline, '14 BRZ, '98 Forester
You should be hitting 60 around 3rd gear. 2nd tops out at 60 IIRC.
Check out Acceleration in gear pic: http://www.ft86club.com/forums/showthread.php?t=10629 Thats for MT. AT's have slightly shorter gear ratios for efficiency so you have to shift a little earlier than stated values Last edited by Xanatos; 08-12-2012 at 01:30 AM. |
#4 | ||
Drives: Asphalt FRS
#5 |
FR-S Owner!
Drives: 2013 FR-S Ultramarine 6AT
Also, be aware that the paddle shifters are VERY sensitive; it's easy to accidentally "double-click" the paddles and essentially skip a gear. I don't believe it actually skips a gear, but it shifts so fast that it feels like it if you aren't careful.
#6 |
Drives: 2013 Argento Scion FR-S 6AT
Same thing happened to me today, except I had it in 4th. Was stop and go traffic on the highway, so downshifted from 5 to 4, then when the road opened up a bit, gave it some throttle, but revs stayed around 1500 no matter how much throttle. Put her over to auto, immediately revved higher and got power. Then back to manual, and problem was cleared. Too identical to be coincidence.
#7 | |
Next time this happens down shift even more and test it out. OP should try it out as well! |
#8 |
Drives: 2013 86 white
Don't treat this real paddle shifter like logitech wheel at home
. Switch to "D" mode till you know some basic MT gear and then go from there.
#9 |
Drives: WRB MT-BRZ LMTD
Anyone else have an AT BRZ? I kinda wish I got the AT version. Ive seen people get over 45+ MPG and I wouldn't doubt that considering I get around 35 MPG in the highway.
I kinda like the paddle shifters better than the stick shift too I find myself rocking the car when downshifting... maybe I need to apply more power so it doesnt rock back and forth? lol.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#10 | |
#11 |
I drove a manual before this car, got AT bc it's DD and Toronto traffic is probably only second to LA traffic. Plus, this AT is really sweet for a slush box.
#12 | |
Keep this in mind you are in 4th... which in MT has a top speed of 109 MPH.. AT is slightly lower than that but still way off from where your shifting at. You should be looking at 2nd or 3rd max at that speed. |
#13 |
Registered you sir
Drives: 99 impreza coupe
Why are these people putting their lugging cars into D instead of just downshift is my question? Have you ever had an issue after one or two downshifts?
#14 |
Drives: none
You're lugging the car. Downshift it again...
| Sat Aug. 25th, Trans Am Nationals Cruise In | oops86 | Other Vehicles & General Automotive Discussions | 1 | 08-09-2012 11:09 PM |
| Got a line on two unclaimed BRZs (manual trans) | Tainen | BRZ First-Gen (2012+) — General Topics | 0 | 07-05-2012 11:40 PM |
| Launch control with auto trans | Dbringer | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-12-2012 05:54 PM |
| Can you manually shift automatic version w/out the paddle shifters? | maxeveland | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 02-01-2012 12:51 PM |
| 6MT vs Paddle shiftting Auto | Dragonitti | Scion FR-S / Toyota 86 GT86 General Forum | 149 | 07-03-2011 01:20 AM |
