01-24-2013, 06:12 PM | #2143 |
Drives: Attitude
A car that sees boost, but doesn't have a boost gauge is stupid. When the WRX came out it wasn't even an option! At least in '03 or '04 I think they started offering the option. Still don't think they're standard in Subarus though.
01-24-2013, 06:22 PM | #2144 |
Drives: 2003 Subaru Outback
AFR and boost should be mandatory on all boosted cars especially with an aftermarket tune
01-24-2013, 06:25 PM | #2145 |
Drives: AE86, 2x GT86, TE27
I'd prefer a stand alone ecu, that can sense all of this automatically, and pull back timing/power if anything goes outside set parameters. A good ecu is going to react much quicker than any driver.
01-24-2013, 06:32 PM | #2146 | |
Add lightness!
Drives: 17' WRX
My 02' wrx came with this gem off the lot: I think I told my friends I was boosting .1 mpa and nobody had a clue wtf I was saying... |
01-24-2013, 06:36 PM | #2147 |
Drives: Attitude
They offered the Lamco in '02? Hm, didn't know that. Thought it was a later addition. I stand corrected. I think they finally got the boost gauges in American units in '08; a whole generation later.
01-24-2013, 08:19 PM | #2148 |
I Love custom Turbo kits
Drives: Limited BRZ
I believe 2 bar+ MAP sensors are about $100? (See Below, Roadstercycle installed an 06+ S2000 4 bar sensor)
01-24-2013, 10:11 PM | #2149 | |
Drives: MR2
Really why ? You going to tell me that you will be looking at those gauges while your driving ? Sorry i dont believe that, then you will probably add another 6 gauges for oil temp etc all over your dash. Not needed at all , proper tune , alarm setting to back off and ability to log so as to see whats happening. A shift light is much better , that way you will see it rather than looking at the tacho |
01-24-2013, 10:21 PM | #2150 | |
01-25-2013, 02:26 AM | #2151 | |
Drives: GTS 86
01-25-2013, 02:30 AM | #2152 |
^ ok but what happens when the car runs more than 5 psi .. You'd never know, also wouldn't be able to have a boost cut for safety.
I guess based on this info i would suggest that anyone getting this kit should invest in a upgraded map sensor . If you run 5 psi you'll want a 7-8 psi boost cut John |
01-25-2013, 08:51 AM | #2153 | |
Pegasus White
Drives: 86
Which MAP sensor do you recommend?
Driving: Pegasus White Manual GTS 86.
01-25-2013, 09:24 AM | #2154 |
01-25-2013, 01:39 PM | #2155 |
Drives: LexusGS,Lotus Exige S240,LexusLX570
I can't wait to get my hands on this kit, but from what I'm reading since i have installed injen intake, Motiv concepts test pipe, over pipe and a Fujitsubo exhaust this kit with it's stage 1 map will not work on my car?
01-25-2013, 04:27 PM | #2156 |
The stage 1 base map would get you started up and to a tuner, but I wouldn't run it hard or long term. Changing that many components brings it beyond the stage 1 parameters.
It's the same as, say, adding a boost controller and running the car at 8psi - the base map isn't designed for that. |
The Following User Says Thank You to AVOturboworld For This Useful Post: | DriftEightSix (01-25-2013) |
Similar Threads | ||||
PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 03:42 PM |
JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 02:19 AM |
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 08:23 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
