#225 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
!Here are some CAD images of the rear louvers. I ended up adding some design flair to them. ![]()
#226 |
Moutain Runner
#227 |
What is the size difference from you large vents? Other than a slight scallop on the aft side looks almost identical to them.
#228 |
#229 |
I would be interested in the s550 ones. Do they include/support rain guards?
2013 Series 10 FRS #553
#230 |
#231 |
due to where they are positioned, do you need to cut into the hood structure vs the 4 smaller ones that sit in-between. I admit really like the look of the S550 GT spec on our cars.
#232 | |
[ame]https://www.youtube.com/watch?v=2DONfLNWghU[/ame] Here is a video of the GT-Spec units going in Clay's car. |
#233 |
Drives: 2014 GT86
VerusEric: i wonder how much (if cut few ribs) that structure is important, and to what extent cutting it reduces rigidity of hood, and if it's worth or not to think of some additional strenghtening in some way (eg. installing something across/behind louvers, to restore/add rigidity), if large vents are installed? Or maybe large vents should be designed in way, that at places where they cut across ribs, there is some extra material/brace/something alike?
#234 | |
#235 | ||
#236 |
Moutain Runner
#237 |
#238 |
Moutain Runner
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 11:18 PM |
| Verus Engineering Air Oil Separator - Information and Release | VerusEric | Engine, Exhaust, Transmission | 127 | 07-08-2023 08:40 AM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 10:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 02:44 PM |
| Verus Engineering Carbon Thermoplastic Splitter Components | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 11-26-2017 06:23 AM |
