#15 | |
Drives: DGM BRZ Limited
#16 |
First Class Speeder
Drives: Silent and Quick
Well its at 29k miles i bought it at 25k i might be clueless maybe in a different aspect :p. This thing aint no knife in butter unless the car has been sitting in the sun over 95 degree weather and i head out for work. That is when i feel the smooth. At night in 60+ degree weather the car is way different on the shifting of gears. To be honest i would not think a big thing of it on the norm...but this car is my baby. I strive for the best i can get for it. Scouring these forums for information and listening to everyone's opinions and weighing in on their input and making the best decisions. After all gotta learn from somewhere.
#17 | |
-Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#18 | |
First Class Speeder
#19 |
Drives: BRZ sold
I suggest you use MTF2 and get 3 liters...you only need 2.2 liters from what I remember. Leave the stock differential oil and just change the tranny oil. If you read the threads on tranny oil and viscosity you will see MTF2 is thin and if you wait a few mintues for your motor and tranny oil to get warm before driving, the shifting will be a lot better.
Unless you plan to run the car hard...why go with thicker oil that makes it harder for the synchros to get lubricated? I believe you will see bigger improvements with shifting with MTF2 versus Motul. I had MTL prior and in the tranny and Motul still in the diff. If I do it again...I just do MTF2 in the tranny. |
#20 | ||
Drives: BRZ sold
I found this post, but can you please explain in detail...so I loosen the nut, but which direction am I turning shaft? so am I turning counterclockwise or clockwise direction of the shaft? Be real cool if you there's a good video or concise instructions. Maybe it's easiest if I go ahead and do it...but I rather get clear instructions and not mess up. Thanks Last edited by imom; 09-08-2014 at 08:25 AM. |
#21 |
Drives: BRZ sold
http://www.ft86club.com/forums/showt...t=clutch+pedal
BTW JP...are you referring to you this link above? That only adjust the pedal height adjustment... in theory it's not supposed to do anything better for the shifting quality going from 1st to 2nd will it? Just like for you to clarify what you meant whether it's the height adjustment or another adjustment? |
#22 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I think my count of local cars that the pushrod adjustment has completely fixed the shifting issues is up to 8 now, with no need to change the oil.
I'm not sure how to explain the adjustment procedure any clearer than my post above you have quoted. If you adjust it the wrong way, shortening the clutch master pushrod, it will make the shift worse as the clutch plate will drag more in the shifts. It only needs minimal adjustment to provide the additional hydraulic throw, with the thread pitch of the pushrod you're getting ~1.5mm of length adjustment for each revolution. On all the car's I've done they've typically needed no more than one turn, but others have reported up to 2 turns has made a massive improvement to the shift. I prefer to do multiple small adjustments rather than one big adjustment, as if you do it too far you risk leaving the hydraulic system engaged and will burn out the throwout bearing/fingers on the pressure plate prematurely or end up with a slipping clutch. |
#23 | |
Drives: FR-S Very Hot Lava
| Automatic Transmission Fluid Cooler. ?? | connor_lol | Engine, Exhaust, Transmission | 177 | 01-02-2023 10:02 AM |
| Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 03:23 PM |
| FS: Redline GL-4 70w80 Transmission Fluid | Tt3Sheppard | Mechanical Maintenance and Tools | 0 | 10-22-2013 01:37 PM |
| What transmission fluid are you using? | Chillz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 04-06-2013 11:45 PM |
| Mt transmission fluid swap | bdanisi | Engine, Exhaust, Transmission | 8 | 02-08-2013 03:09 PM |
