Old 02-07-2013, 04:55 PM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Mt transmission fluid swap
What do you all prefer for maximum buttery smoothness. The pentosin, motul or something else?
bdanisi is offline   Reply With Quote
Old 02-07-2013, 06:01 PM   #2
zuldajin
zuldajin's Avatar
Drives: K24 Swapped FRS
Let me redirect you to...
http://www.ft86club.com/forums/showthread.php?t=16604
zuldajin is offline   Reply With Quote
Old 02-07-2013, 06:04 PM   #3
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I've switched to Motul Gear 300 and it is awesome once the transmission is all warm but it still has problems when it hasn't warmed up yet. Better than stock but I think a thinner fluid like Pentosin is going to perform much better in that warming up period. I've got some on the way that I'm going to try next. I'll report back how I like it compared to the Motul.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 02-07-2013, 10:03 PM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
I've tried Redline's MT-90, and liked it until the weather turned cold (into the low 40s F/5 Celsius or so). Others have reported good results With MT-85. I've had great luck with Pentosin in temps as low as -23 C/-10 F. Good stuff, but It's not cheap to buy.
Old 02-08-2013, 02:18 AM   #5
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Pentosin is working well for me in the near freezing temperatures.
stockysnail is offline   Reply With Quote
Old 02-08-2013, 03:11 AM   #6
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Pentosin is the name. So glad I change to that fluid.
tintumz22 is offline   Reply With Quote
Old 02-08-2013, 07:50 AM   #7
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Can someone link where to buy that Pentosin fluid?
Bg8780 is offline   Reply With Quote
Old 02-08-2013, 08:26 AM   #8
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Oriley auto parts sells them. Call them up
LeeMaster is offline   Reply With Quote
Old 02-08-2013, 03:09 PM   #9
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Don't do this they have to special order it and it takes forever. I ordered mine here
http://www.autohausaz.com/search/pro...er=83220309031
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 05:53 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
