Old 05-18-2018, 04:25 PM   #29
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by guybo View Post
the battery may be 1%o fthe weight of the car, but you are moving it from right on top of the longitudinal COG to the extreme rear of the car so you aren't moving 1% of the weight from the front to the back. It's from the middle to the back. You are increasing the moment arm of that weight from the center of the car out quite a ways which will cause the rear of the car to carry the inertia of that weight when cornering. If anything, the car will feel more sluggish in a corner and will want to carry a tail slide longer and be more difficult to catch. You can't just add and subtract the weight, you have to calculate the vectors of the weight. Plus, like @bcj said, extra weight.
There's also the safety factor. Batteries often off-gas when they get older and the gas is hydrogen (boom) and hydrogen sulfide (toxic). You will be closed in the same compartment with this thing.
http://www.orlandosentinel.com/news/...004-story.html
Yeah, I was just estimating. Is it accurate? No. Is it something to show approximate scale of the change? Yes.
As far as moving weight rearwards, the rear of the car has the smallest radius from the center of the turn, meaning the smallest moment arm to rotate the weight about. Suspension comes into play here, but in general the car will rotate more willingly if more weight is supported by the rear wheels.
Old 05-18-2018, 04:44 PM   #30
kowalski
kowalski's Avatar
Drives: 2016 brz
Originally Posted by Mr.ac View Post
Personally, it's not worth the time and effort. If your not in actual racing competition where 2 lbs can mean a win or loss, your just "ricer-ing" yourself.
I am not in actual racing competition. But OEM Battery is listed as 29.6 lbs. So it is still quite something... The other option is to retune the suspension on the car, but then I guess I'll have to buy some coilovers or shocks (which I do not have). In any case it is interesting to sort the pros and cons of doing it.
PS: Though it seems that there aren't many pros then thx for all the comments. I guess I'll leave it as it is and wait for a fine tuned suspension.
kowalski is offline   Reply With Quote
Old 05-18-2018, 04:53 PM   #31
Why re tune the suspension for the battery weight? The car was designed with the battery there and no doubt the engineers that did the work took it into account. It isn't like they built the car and then went "Oh god we forgot the battery where should we shove it/"
Old 05-18-2018, 04:59 PM   #32
kowalski
kowalski's Avatar
Drives: 2016 brz
Hi there @Tcoat. It is not for the battery weight, is for the supercharger install... I've read and seen some guys who do adjust their suspension after a FI install.
Old 05-18-2018, 05:03 PM   #33
AHHHHH I see. Well that isn't really necessary either unless you are hitting the track hard. A street driven car should not be used in a manner where advanced mods are of any benefit.
Old 05-18-2018, 05:22 PM   #34
ST185RC
Drives: White Out FR-S
If you are not racing the car, doing all this extra minuscule stuff is a waste of your money. You will not feel it outside of a competitive course. the extra load of the super charger is like putting a chick in your car. Pretty sure the stock suspension settings can handle that. you see those massive 250lb guys shoehorning themselves into the car? I really doubt those guys have to retune their suspension each time they get in.
Don't overthink it. you have a supercharger, just enjoy it.
ST185RC is offline   Reply With Quote
Old 05-18-2018, 08:06 PM   #35
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
And a bunch of bags of fertilizer?
You just went onto about 10 different watch lists.
There are already bags of fertilizer around the trunk hinges. Poor car.
Old 05-19-2018, 01:10 AM   #36
Ultramaroon
not playing cards
Ultramaroon's Avatar
<12 parsecs, bitch
Old 05-19-2018, 01:25 AM   #37
Sapphireho
Famous Potatoes
Sapphireho's Avatar
<12 parsecs, bitch
Snooze, what have you done !ately?
Old 05-19-2018, 01:30 AM   #38
Ultramaroon
not playing cards
Tonight I shaved material off of a couple parts of the mocal adapter so it cinches up tightly.
Most valuable tool in the garage is that harbor freight belt sander.
Old 05-19-2018, 01:47 AM   #39
Sapphireho
Famous Potatoes
Sapphireho's Avatar
<11.95 parsecs?
Old 05-19-2018, 03:00 AM   #40
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
It involved a 5 minute video clip and a box of tissues.
Old 05-19-2018, 03:16 AM   #41
And as per usual Snooze does not disappoint when he appears.
Old 05-19-2018, 05:05 AM   #42
Captain Snooze
Drives: Red Herring
That's funny.
At first reading I saw "as per usual ooze does not disappoint when it appears."
battery, relocation, trunk
Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down OAKOS Automotive Exterior Parts - The Rest 216 09-09-2016 12:40 PM
Relocating Battery to trunk ML Engine, Exhaust, Transmission 35 08-03-2015 01:58 PM
Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down OAKOS Automotive Exterior Parts - The Rest 170 01-20-2015 12:47 PM
DIY Battery Relocation - pic heavy Target70 DIY (Do-It-Yourself) Guides 0 07-05-2014 03:27 AM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
