Drives: 2016 brz
battery at the trunk - relocation
¿Anyone has done a battery relocation to the trunk of the brz? I am interested in doing so as a way of counterbalancing weight after a SC install. Not interested in lightweight batteries. Thing is I haven't seen many installs. Indeed. None.
I know some Audi cars, for instance, have the battery fitted inside the spare tire location at the trunk. Any pros or cons of doing this in the brz? Thanks! |
[insert cool phrase here]
Drives: BRZ Premium
Personally, it's not worth the time and effort. If your not in actual racing competition where 2 lbs can mean a win or loss, your just "ricer-ing" yourself.
If all you do is daily driving or "sprinted mountains driving " then it's still not even worth it. Your better off with a light weight battery. And even then why?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 2013 frs
Relocating a battery is pretty simple for the most part but also if done wrong may end up in your car catching fire.
Personally you’re better off with it in the front Sent from my iPhone using Tapatalk |
#4 | |
The Dictater
Drives: '13 Red Scion FRS
![]() Now that everyone is all riled up, I'm going to say that I also do not recommend doing this, even on a race car. Batteries store a whole lot of energy, and you don't want a main unfused line in the cabin. Running the line outside is likely to get it damaged or corroded. You have to have pretty thick cabling on the positive wire to reduce resistance, and that long of a wire might produce more interference in the electronics' power supply, increasing the likleyhood of a fault. In a race car, you would be better off getting a super small, lightweight battery because it only needs to crank once (or twice if something unfortunate happens) and usally in not-cold weather. |
not playing cards
Meh, AGM battery with a decent ground strap in the back. One single heavier gauge conductor carefully mounted under center console with a fused link at the battery.
Win.
#6 | |
The Dictater
Win revoked. |
#7 | |
not playing cards
Live. Learn. Do. Win.
#8 | |
The Dictater
![]() JK, I'm sure there's a legit way to do it, but still not recommending messing with it.
The original set up is also a solid design with no real world advantage to re-engineering the whole system. This system significantly increases risk by extending the potential points of failure through the whole vehicle. Sure you can manage that increased risk through the things you said but I think a deeper PFEMA would tell you it is not necessarily a good idea. If the benefits outweighed the risk it may be worthwhile pursuing but I just don't see that for this application.
#10 | |
not playing cards
There's a great deal involved in doing it right but it can be done. Benefit schmenefit. Of course it's silly but so's a snooker ball for a shift knob.
#11 |
Drives: 2016 brz
"win revoked" LOL.
#12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Main reason for re-location was usually no more room under the bonnet with the V8 shoehorned into Sunbeam Tigers and Cobras.
I think Sunbeam Alpines still had the battery in the engine bay. Also another 5 to 10 lbs. extra copper leads.
"I gotta rock." -- Charley Brown |
#13 | |
When we were building the new assembly plant I spent a great deal of time in Detroit monitoring the engineering firm contracted to design and build much of the line equipment. Now, this was not some mom and pop shop but the leading automation company in the world. The whole reason I was there was that they had a horrible tendency to want to make everything overly complex. The best example of this was the task of installing the three 5/16 (socket size) bolts that hold the rotor splash shields on. They proposed this massive device that looked all the world like a minigun on a swing arm. The operator would place three 1/2 inch long bolts in the sockets, swing the thing in place, line it up with the holes, pull a trigger and wait until it hit the preset torque and stop. then they would swing it back and start all over. This task was given a 20 second cycle time. So, I told them that it would never work and to make something simpler . They went over my head to the corporate engineering director and he said build it as designed. Well guess what? It didn't work. Try standing back almost 4 feet and line three small bolts up with holes you can hardly see due to the bulk of the equipment. The 20 second cycle time was extended to over a minute and that just could not happen. After fighting with corporate for a week we eventually pulled the massive thing and gave the operator a small pneumatic had driver which I wanted in the first place. The cycle time went down to 10 seconds and the operator was actually even able to do a second task as well. THIS is why I dislike over engineering and moving a battery to the rear of the car for no appreciable advantage is certainly that.
#14 |
not playing cards
| Tags |
| battery, relocation, trunk |
| Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down | OAKOS Automotive | Exterior Parts - The Rest | 216 | 09-09-2016 12:40 PM |
| Relocating Battery to trunk | ML | Engine, Exhaust, Transmission | 35 | 08-03-2015 01:58 PM |
| Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down | OAKOS Automotive | Exterior Parts - The Rest | 170 | 01-20-2015 12:47 PM |
| DIY Battery Relocation - pic heavy | Target70 | DIY (Do-It-Yourself) Guides | 0 | 07-05-2014 03:27 AM |
| Battery in the trunk | scottman | Electronics | Audio | NAV | Infotainment | 14 | 10-06-2012 08:26 PM |
