Old 05-19-2018, 01:32 PM   #43
That's funny.
At first reading I saw "as per usual ooze does not disappoint when it appears."
Well that too.
Old 05-21-2018, 02:07 PM   #44
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Holy jesus thread is hilarious!
Literally everyone claimed a different answer by invoking a different scientific subject.
Statistics was invoked to discourage through risk assessment.
Mechanical Engineering was invoked to discourage through weight transfer & inertial changes.
Inorganic/Organic Chemistry was invoked to discourage through flammable/toxic gases coming off of the battery due to interaction with the surrounding atmosphere (air we breathe).
Electrical Engineering was invoked to discourage because of cold cranking & amp drops under some blah blah condition.
So just to keep up the negative streak I would like to add...
Thermodynamics: Your car is going to dissolve into its basic elemental components as time goes to infinity... According to the 2nd law of thermodynamics you and your car are going to be screwed anyways regardless if you move your battery.
TachyonBomb is offline   Reply With Quote
Old 05-21-2018, 03:15 PM   #45
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
It's the Di-Hydrogen Mon-Oxide.
Sucks, but there it is.
"If you get some on your finger, you can wipe it on the wall." -- Zappa
Old 05-21-2018, 04:17 PM   #46
Ultramaroon
not playing cards
Ultramaroon's Avatar
Isn't it all just math?
Old 05-21-2018, 06:00 PM   #47
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
heh only noobs in here..i run my 86 without the battery ^^
HKz is offline   Reply With Quote
Old 05-21-2018, 06:01 PM   #48
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That's funny.
My ooze never disappoints, if you know what I mean.
Old 05-21-2018, 07:11 PM   #49
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I mean, if you really want to get philosophic, everything is just information. The differences between a person and a rock and a car and a body of water is the way in which a few types of sub-atomic particles are assembled. And the difference between those few particles is the way in which smaller particles are assembled.
But I digress...
Old 05-21-2018, 07:23 PM   #50
Sapphireho
Famous Potatoes
Sapphireho's Avatar
But I digress...
Some particles are assembled better than others.
Old 05-21-2018, 09:54 PM   #51
Spuds
The Dictater
Spuds's Avatar
Another day, another panic scroll at work.
Old 05-22-2018, 11:14 AM   #52
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I was just adding to the philosophical particle discussion.
Back on topic. Battery in trunk?
Old 05-22-2018, 11:18 AM   #53
Spuds
The Dictater
Spuds's Avatar
No.
Old 05-22-2018, 12:14 PM   #54
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by kowalski View Post
Hi there @Tcoat. It is not for the battery weight, is for the supercharger install... I've read and seen some guys who do adjust their suspension after a FI install.
I believe you are a bit confused. You don't change the suspension after a FI installation because of the extra weight, but because of the need to get wider wheels/tires and have more grip.
battery, relocation, trunk
Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down OAKOS Automotive Exterior Parts - The Rest 216 09-09-2016 12:40 PM
Relocating Battery to trunk ML Engine, Exhaust, Transmission 35 08-03-2015 01:58 PM
Rally Armor Mud Flaps, Grimmspeed Plate Relocation Kit, Oil Caps and Battery Tie Down OAKOS Automotive Exterior Parts - The Rest 170 01-20-2015 12:47 PM
DIY Battery Relocation - pic heavy Target70 DIY (Do-It-Yourself) Guides 0 07-05-2014 03:27 AM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
