#85 |
Drives: 2015 Scion FR-S Halo
#86 |
Huge E85 fan!
Drives: 2016 Scion FRS
Today I took the plunge and did the clutch spring delete. I only drove about 30 miles (mostly highway) with it, so the jury's still out.
-Clutch throw is a lot less -Clutch pedal is a lot harder to press now -Shifts are more precise -The clutch in my car no longer feels like the clutch on my Thrustmaster T500 sim racing wheel When I get stuck in a traffic jam (just a matter of time in Tampa...) and I shift in to first 100 times in a mile, I'll know if the spring has to go back on or not. |
#87 | |
Drives: 2013 Subaru BRZ Limited (CBS)
2016 Scion FR-S
1991 Acura NSX 2012 Mazda Miata (Track) 2019 Triumph Bonneville Bobber 2007 Suzuki SV650 (Track) |
#88 | |
Drives: 14 BRZ Red premium
i drove a stock brz, and went WTF... 0 effort and the pedal is on the floor Funny thing is ..form stock to spring remove , i didnt feel needing much more effort to clutch in.. But i guess is not the same when you go back to stock with assist spring.
#89 | |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
When I removed my spring, I took everything off and did not reinstall. Spring, pin, e-clip, clevis. Took them all off and put them in a zip-lock bag in case I ever decide to put it back. Without the spring there, the clevis, pin, and e-clip really serve no purpose anymore so they do not technically need to be reinstalled. Over 30k like this now and zero rattles or issues.
@bpennerz
#90 |
Drives: 2014 WRB BRZ Limited
It's probably worth noting that after doing this mod, you'll actually be able to tell where the bite point is, unlike the stock clutch. So if you're adjusting the pedal height as well (which is strongly recommended), you may need to adjust it over time. As your clutch wears, the bite point will slowly move closer to the top of the pedal. No big deal, but worth mentioning. For reference, I've adjusted height twice in almost 50k miles. My clutch is slightly lower than my brake pedal now and I've got just a bit of dead play off the floor, which is what you want.
Still my favorite mod!
#91 |
Huge E85 fan!
After a few weeks and a few traffic jams it's still awesome. I have the pieces in my glove box in a bag, but I'm not going back. I love this mod.
9 years ago I sprained my left knee. Sometimes in certain weather or on some random days I starts bothering me. That's what I was afraid would be a problem. With my old tC it'd bother me in traffic a lot, with my old GenCoupe it'd bother me sometimes. So far the FRS had given me 0 probs even with the spring delete. |
#92 | |
Drives: 2016 ZC6
My build thread: Pointmutation's WRB BRZ build
#93 |
the clutch definitely feel better, but is there anyway to adjust it so it doesn't have the wiggle room when its fully released? mine has some minor movement where you can just wiggle it before actually putting pressure on the clutch peddle.
#94 |
Use the clutch position sensor (threaded rod with the 14mm nuts and white pin inside) to take up the slack. Try to position it so it just barely touches the pad wheel the clutch is released. No more play at the top. You have to adjust that after you lower the pedal anyways.
#95 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Did this exactly as suggested by @xxbrunoxx. Well pleased with result. Thanks for the DIY guide.
#96 |
Drives: swp mt '14 brz premium
Finally removed my spring yesterday. I removed the fuse panel cover, then the lower dash panel, un-plugged the 3 connectors, and then removed the metal plate that's held on by 2 10mm cap screws---this gave me a little more room under there. It was hard work for me but so worth it! I also installed the 3/4" slave cylinder awhile back, so I have a firm pedal. My last car was a Toyota p/u with a hydraulic clutch and this car drives like that one now. Thanx to everyone who contributed to this thread!
Last edited by jcw99; 08-03-2016 at 10:39 AM. Reason: had to delete emojis and extra words |
#97 | |
Drives: GT86 raven
#98 | |
The clevis and other related parts are simply there to connect the helper spring assembly to the clutch pedal; that's it. They don't actually connect the clutch to the car or really do anything else. Once the spring is removed, these parts are completely unnecessary, which is why a lot of people (myself included) opt to just not re-install the parts without the spring. Hope this helps!
@bpennerz
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-15-2017 12:44 AM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 04:42 AM |
| Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 11:14 PM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
