| AUSTRALIA Australia and New Zealand |
Drives: 2012 86 GT
Clutch spring removal
Has anyone removed the spring on the clutch pedal. Its there to make the clutch easier to depress. I dont like the feel and would like to remove it or put in a weaker spring.The LHD guys in the US say you can do it in 15 minutes.Not in a RHD car. HELP Sandy in Nelson NZ
Señor Member
Did you see this already?
http://www.ft86club.com/forums/showthread.php?t=84622 I can't imagine it beings that much different from LHD to RHD, but then again I've never been in a RHD 86. |
Drives: 2012 86 GT
Spent an hour under there . Its all on the wrong side.You can see the spring but cant get to it. May have to remove the complete pedal from the fire wall??
Drives: White GT 86 Manual
It can be done no real problem, it's not as easy as LHD drive looks to be but definitely do-able, start with removing actuating from pedal by taking the pin from the clevis, this gives you a bit more room to move.
Push the rod from the spring, it's tight but can be done, then lever the spring out. I totally recommend this mod, best thing I've done. |
Drives: 2012 86 GT
Not being a quitter I had another go at it.My back will be better in a few days. I got my 100 k body in far enough to see the clip.Pulling it out would have to be done with your left hand . I am right handed and cant scratch my ass with my left hand. Guess I will be looking for a small left handed wrench operator. Cheers Sandy
| MTEC clutch spring review | kbye | Engine, Exhaust, Transmission | 23 | 04-26-2023 06:48 AM |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-15-2017 12:44 AM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
| Need help: Clock Spring Removal NRG Hub install | Iwannajag | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-20-2015 05:30 AM |
