Old 01-14-2016, 01:43 PM   #1
peaches
Drives: '14 BRZ Limited
New OFT, unable to read ECU
Hi,
looking for some assistance. Received a new OFT as a gift, purchased from FT86speedfactory. I'm currently unable to read the ECU.
Background data:
- car was purchased brand new, 120 miles on the clock
- no other tuning has been performed by me
- '14 BRZ Limited
- radio is off, AC is off, radar detector is disconnected, lights are off, doors are closed
1. Connected OFT to laptop, OpenFlash Manager ran updates for several minutes.
2. Connected the OFT to the car, set car to ON (push start button twice, engine off), OFT says ECU is in recovery mode.
3. Disconnected and reconnected ODB cable, in case there was a bad connection. Repeated step 2, same result.
4. Tried to read the ECU info, nothing came back.
5. Disconnected OFT, turned car on, no issues. Turn car off.
6. Reconnected OFT, tried to read again, same issue.
7. Tried to read trouble codes, "operation failed".
8. Turned car on, tried to read live data, "operation failed".
9. Searched the forums for a similar issue, didn't help.
10. Went back to the car, disconnected and reconnected ODB cable, tried again. Same results.
I've read instructions and recommendations on the forum, don't think I'm missing something. Any ideas?
peaches is offline   Reply With Quote
Old 01-14-2016, 03:19 PM   #2
steve99
possible bad obd connection, see if oft will do diagnostics or access ecu info on another 86 car, dont do read ecu or write ecu just diagnostics or read info.
make sure cable is plugged into oft at oft end.
some cars have suspect obd ports, will something like a blutooth obd adapter work in obd port or obd scanner, i think it port unless oft is stuffed
Old 01-14-2016, 03:21 PM   #3
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Good to hear the car still starts. I know you said you double-checked your OBD2 connection but is there any visual evidence of a bent or dislocated pin in either the cable or the connector on the car? A mirror might be helpful in looking at the car-side port.
theadmiral976 is offline   Reply With Quote
Old 01-14-2016, 05:17 PM   #4
peaches
Adding some details in case someone finds this thread later on, and has the same issue.
Shiv suggested to disconnect the battery to force the ECU to reset, that did the trick. I was able to read and write the tune.
Something else that was weird is that before I wrote the tune on the car, OpenFlash Manager wasn't able to show me the tunes on the tablet. It kept showing me the initial screen where it looks for the device and showed over 1000% or progress made... after that the program was unresponsive. After I wrote the tune, it showed everything fine.
When the tablet generated the tunes, I didn't know if the stage 1 it showed me was for 91 oct or 93 oct. I was able to replace the generated tunes though, I use 93 in Ohio. Would like to try the E85 tune, but it's not readily accessible at the tracks I go to, and I don't want to carry a full tank worth of E around or deal with switching back and forth.
Something else I'm waiting a response on, does Windows 10 need the Windows 8 patch?
Old 01-14-2016, 05:21 PM   #5
peaches
I have heard some cars have faulty ports, especially the first ones. Never used the port until today, we'll see what happens from now on. It seems the ECU was in a strange state, I went to the dealer on saturday so I don't know if they did something.
My idle was dropping too much when I coasted to a stop and had the AC on, I asked the dealer to check the ECU version but they said it had the latest, no updates were done according to their report.
Didn't check to see if any of the pins was bent, will do that if I continue to have issues.
Old 01-15-2016, 12:21 AM   #6
keen as
keen as's Avatar
Drives: 86 GT MT
When I updated my old laptop from Win7 to Win10, no patch was needed.
keen as is offline   Reply With Quote
Old 04-01-2016, 06:27 PM   #7
choiboie
Drives: 2013 Fr-S UltraMarine
man i just ran into this problem.. i did the battery reset and still no read or write
choiboie is offline   Reply With Quote
Old 04-03-2016, 08:20 PM   #8
dutchdabomb
Similar Problem
I have a similar problem with my 2013 BRZ Limited manual. I got the OFT on April 2 and auto-updated it with OpenFlash Manager on Windows 10. I then plugged it in and went to Tuning > Toyota > GT86 > [ZN6] 2000 D4-S 200 HP FA20 > Read. At the prompt to key on and confirm, I did so and pressed OK. These screens then flash rapidly:
Communicating with ECU
Please wait...
Preparing to Read
Please wait...
An error occurred
while reading data from ECU
Please try again.
I've also done the process with the engine already running, but with the same result. Here's a video of two attempts of that:
https://vid.me/if6h
Overall, I'd tried it about 6-10 times with the same error each time. This thread recommended disconnecting the battery, so I tried that (both poles) but still get the same result despite multiple tries. I also checked the pins on both ends of the provided ODB-II cable as well as the OBD-II port on the car and they all look straight to me.
One thing that does work is the Diagnostics screen. I'm able to see real-time statistics (e.g. RPM, throttle percentage) as the car runs.
Any ideas on how I can get the OFT to read the ECU so I can proceed with the tune?
PS: The car is stock so I'm looking to do the off-the-shelf (OTS) stage 1 tune for 91 octane (California).
dutchdabomb is offline   Reply With Quote
Old 04-03-2016, 08:57 PM   #9
choiboie
Please wait...
Preparing to Read
Please wait...
An error occurred
Please try again.
https://vid.me/if6h
I'm taking my car into the dealer this week..for oil change. But told them my idle is acting funky so they'll check the ecu
Sent from my SM-G920V using Tapatalk
Old 04-03-2016, 08:58 PM   #10
steve99
Please wait...
Preparing to Read
Please wait...
An error occurred
Please try again.
https://vid.me/if6h
Never have engine running while trying to read or write ecu tunes/rom.
you need ignition full on (not just accessory) with engine NOT running.
ie two pushes of start button (or key full on) dont press clutch or in auto leave in park so engine does not start
only diagnostic mode can have engine running
Tips to help you avoid Bricking your ECU
http://www.ft86club.com/forums/showthread.php?p=2489551
Old 04-03-2016, 11:14 PM   #11
dutchdabomb
Thank you for the tip. This did the trick! I was interpreting "key on" to mean "turn the engine on" instead of just the ignition. Once I pressed the start button twice (with the clutch out) it was able to read and write the tune.
Thanks again!
Old 04-07-2016, 12:01 AM   #12
choiboie
So after dealer visit and stopping by autozone it's definitely not the obd2 port..they were able to read ecu an look for codes..which ending up clean with no cel.so im assuming I need a new cable or tablet 😂
Old 04-07-2016, 01:11 PM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
that sucks
Old 04-19-2016, 02:52 PM   #14
choiboie
Originally Posted by NyC Zn6 View Post
that sucks
Culprit was the cable. Should have the new unit and cable by tomorrow!!!
Unable to find auto dimming mirror connector 1040 Cosmetic Modification (Interior/Exterior/Lighting) 2 12-28-2015 11:52 AM
EcuTek Unable to Increase Load Limits Skorov Software Tuning 35 06-25-2014 01:56 PM
Unable to loosen crank pulley, even with 6 foot break bar! tbertran Engine, Exhaust, Transmission 36 05-20-2014 02:34 PM
Unable to program TPMS if you have Ecuteck? EL7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-04-2013 05:20 PM
Unable to hold idle. CSG Mike Issues | Warranty | Recalls / TSB 22 05-20-2013 07:00 PM
