Southern California SoCal
Old 04-12-2016, 08:02 PM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Car needs a new transmission but Subaru wont cover it under warranty..
Hey guys,
Need some advice. My car needs a new transmission because of gears grinding on 6th. Subaru will not warrant it because my car is "fully catless" and they are blaming the extra power being the cause of my transmission failing. So they've flagged my car in southern California... They told me the cost to replace it would be around $7000!
If you were me, what would you do? Need as much advice as possible on this. Honestly don't think that its really fair, to consider such a modification to even be able to do that.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 04-12-2016, 08:05 PM   #2
Binary_fission
Binary_fission's Avatar
Drives: FRS
Look for used transmission, there's few posts on Fb and u might find some here, people who have done engine swaps. Or rebuild it else where never go to dealer unless ur car is stock.
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 04-12-2016, 08:06 PM   #3
tracerit
Drives: '13 SSM BRZ Limited 6MT
Which dealership did you go to? Did they specifically say you were flagged?
Your sig says youre supercharged as well... Hopefully you disconnected all that prior! haha
tracerit is offline   Reply With Quote
Old 04-12-2016, 08:24 PM   #4
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I feel like the supercharger would be more of a concern than a lack of cats. That is my logical approach to it, anyway.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 04-12-2016, 08:32 PM   #5
rhythmM
rhythmM's Avatar
They did tell me my vehicle got flagged, there was a corporate rep visit today. And I did take off the supercharger. But I left the car catless.
Lesson learned, I just didn't think they would pin the reasoning on having no cats..
Old 04-12-2016, 08:34 PM   #6
Crazypinoy9
Drives: FR-S TRD RS1#1488
don't they have to prove that the "extra power" actually caused the problem? cuz what did that give you? 2-5 hp? lol
doesn't the Magnuson–Moss act come into affect for this situation?
Crazypinoy9 is offline   Reply With Quote
Old 04-12-2016, 08:55 PM   #7
ryoma
ryoma's Avatar
as far as I know about this denial of warranty issue is that the dealership can deny warranty services for anything. it is up to the customer to PROVE that the dealership is wrong in their denial of warranty. and the only way to prove it is through the courts, or a call to the higher ups (good luck with that)
Old 04-12-2016, 09:02 PM   #8
Binary_fission
Drives: FRS
It doesn't matter, dealer will find any reason not to do free repair. Its like when u get pulled over for nothing but cop has to give u ticket so hell find something. Only time dealer will warranty is when u haven't done nothing to the car and daily drive the car.
Also remember car logs highest rev and saves it in ecu. If you red lined the car they will know and it voids drivetrain warranty
Old 04-12-2016, 09:05 PM   #9
Crazypinoy9
https://www.consumer.ftc.gov/article...ne-maintenance
"Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. The manufacturer or dealer can, however, require consumers to use select parts if those parts are provided to consumers free of charge under the warranty.
Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage."
getting a ticket from a random spot check by a cop is different. He has every right to ask you to pop your hood and check for illegal parts and ticket you if that part is technically illegal. The OP's situation is that he's being denied warranty for something that isn't directly correlated to the issue. they're literally bullshitting him to save themselves the cost of repairs.
Old 04-12-2016, 10:54 PM   #10
rhythmM
rhythmM's Avatar
Do you think this would still apply to me? They told me the reasoning behind my gear grinding is because of the, "increased power from not having any catalytic converters caused the synchros to become defective" (something like that) which is total bs.
Old 04-12-2016, 11:12 PM   #11
CatalystPLUR
That Auto Guy
CatalystPLUR's Avatar
Drives: Ultramarine FRS
They gave a reason why the aftermarket part was causing the defect. In your case you could probably fight them on it and win. But that would involve lawyers hiring an expert to argue your cause and days out of your schedule.
You would save money just going out and getting a used transmission or even a new one.
CatalystPLUR is offline   Reply With Quote
Old 04-12-2016, 11:26 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Since you already took the car to attempt warranty and there are documented mods that SOA is using to deny a claim, basically it is a lawyer situation.
You have to get them to prove that your mods contributed to the powertrain failure.
But honestly, this could've been avoided if you had 1) a better relationship with the dealer, or 2) taken off ALL engine-related mods. If you are doing things beyond the rated torque capacity of the transmission, that's a very good reason to deny warranty coverage on the transmission.
Their reasoning is BS but valid. Up to you if you want to hire a lawyer for this or not...
-alex
Old 04-12-2016, 11:33 PM   #13
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Thanks to this thread, I will keep all my OEM parts when replaced... such bullcrap bro.
hypebrz is offline   Reply With Quote
Old 04-13-2016, 12:26 AM   #14
AlanLGuy
Drives: Raven 6 speed Manual FRS
Hey guys,
If I were you, I'd forget the dealer, doubtful you'll make any headway and a lawyer will end up costing you more.
If I were in your shoes, I would buy a used transmission, swap it in with a buddy, then either sell current transmission as is, or replace the 6th gear synchro myself and sell it for what I have in the used transmission. Not out anything but time and effort and minimal downtime.
If you can't afford that at the moment and don't have another car, drive the car until you do, avoiding 6th gear, if you continue to use it with bad synchro a you'll take chunks out of the gear and wind up replacing it as well. You'll get bad mileage on the highway, but as long as you aren't doing 80-85 on a regular basis... 5th gear will get the job done
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
6MT Transmission Grind -> Warranty Replacement (Subaru) Fred E NY / NJ / CT / PA 7 11-07-2015 12:18 AM
Would paint chips will be cover for the new car warranty? Jfheisenberg Issues | Warranty | Recalls / TSB 54 03-06-2015 10:42 PM
Which dealer to go for transmission warranty ironsurfer129 Southern California 17 02-21-2015 04:16 PM
Transmission warranty. Reaper Engine, Exhaust, Transmission 28 10-10-2014 07:29 PM
