Drives: 2012 86
OEM small(er) battery tray - Installed
While researching replacement for my OEM battery I came across this: http://panasonic.jp/car/battery/teki...a&cnm=%82W%82U The JDM 86 came from the factory with a smaller 34B19R (thus lighter) battery, except 'cold climate' cars which get 55D23R. For whatever reason, the rest of the world get 'cold climate' cars with 55D23R (RHD) or 55D23L (LHD) batteries. I asked around and turns out it was a very easy conversion to use the smaller size battery. Source (Japanese): http://minkara.carview.co.jp/userid/...7169/note.aspx You need to order 3 parts (the 3 parts below the purple battery in the photo above): SU003-02412 Battery pan SU003-02414 Rod SU003-02418 Holder You also need these to convert the smaller terminals on the smaller battery to be compatible with the connectors: http://www.zoomerroo.co.uk/small-pos...is-to-sae.html OR you could order more OEM parts to convert the car connectors to smaller ones, but you need to figure out the exact parts needed as I was not resourceful enough to do so (the diagrams confused the hell out of me ).Result below. It was as easy as swapping in another OEM battery. Actually it's easier as the smaller battery means the Radium catch can I have no longer gets in the way. Compared to the OEM battery, this saves anywhere from 2.5kg / 5.5lb to 6kg / 13.2lb depending on the particular battery you can buy. In where I live people are crazy about 'blue' (Panasonic CAOS) and 'purple' (GS Yuasa ECO.R) batteries so those are the only ones available. Unfortunately those are actually heavier than the OEM Panasonic. To make things worse nobody imports them at B19R size as no other car uses that size, so I had to settle for the heavier B20R size. Still I think the conversion is a no-brainer as the price difference between B20R and D23R sizes alone is more than enough to pay for the parts. Compared to existing lightweight battery solutions, this is nowhere as light (11kg / 24.2lb) but at just a fraction of the cost. Apparently there are 4.5kg batteries available for the size (see Japanese link above) so there is more weight savings to be had. This conversion is also 100% OEM for those who care. Battery weights: OEM Panasonic 55D23R: 13.5kg / 29.7lb Panasonic CAOS Pro: http://panasonic.jp/car/battery/caospro/cp01.html Panasonic CAOS: http://panasonic.jp/car/battery/caos/ca09.html GS Yuasa ECO.R: https://gyb.gs-yuasa.com/product/carbattery/ecor_ll/ Last edited by akyp; 09-04-2016 at 02:54 AM. Reason: Fixed link |
Drives: GT86, 22 BRZ
SU003-02414 Rod SU003-02418 Holder Are these Toyota or Subaru part numbers? |
Drives: 2012 86
The Fail Boat
Drives: CWP S.B.
Thank you for a great find like this. 😀 Now I know where to get a cheap battery tray when I get a smaller battery.
Drives: UltraMFrS
Any other pro and cons besides weight reduction?
Sent from my SM-P600 using Tapatalk |
#6 | |
Drives: 2012 86
With the bigger battery I have jump started my dad's car with a V8. Now I would think twice about that. Other than that I can't think of any drawbacks with the smaller battery. |
Drives: 15 BRZ LTD, 05 FXT
Can someone help us out with Subaru part numbers?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Resident Gear Head
Cold cranking amps as mentioned in another quote colder climates where freezing temps occur the oil is like sludge and to get the car started the smaller battery may not be able to do it. Temp effects amperage just like commonly when cold out batteries are weaker.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
Pros: Weight reduction, most likely able to handle an AGM LW in an OEM like fashion. (I intend on doing this with an Odyssey PC680.)
Cons: Can't listen to your stereo for hours with the ignition off.... A lot of the pros/cons will vary depending on which battery you pick. A lot of lightweights are finnicky with how long they sit, and how you charge them, and cold weather, others are more stable than a typical lead acid at temp, and can sit longer as long as there is minimal drain on the battery.
#10 |
Drives: 2013 Firestorm FRS
so what is the cost?
#11 |
Drives: 2014 Whiteout Monogram 6MT FR-S
This thread helped me get all the parts/pieces to make an Optima Yellow Battery install. Thought this might be helpful as well, it's a link to the Optima Battery install I did... has pictures toward the end.
http://www.ft86club.com/forums/showthread.php?t=117178 BTW the D51R Optima Yellow top was $214.19 +13.54 tax = $227.73 ($12 core deposit, so actually $215.73, with 10% discount) military. |
#12 |
Drives: 2014 GT86
IIRC most in EU had 48Ah Panasonic battery fitted stock. But for many it went flat even in first year and in most cases Toyota replaced for free with 65Ah one. So far i hadn't have replacement go flat, so unless it's for track day only, i'd never think of less capacity for daily driven all year round. And if weight at track is reason for temporary switch, then imho even much smaller/lighter batteries make better choice, as compromise of something in between will be jack of all trades/master of none. Not as light at track, and not with capacity for carefree daily driving.
| Lightweight battery that fits the stock tray and tie down? | SPCorBUST | Engine, Exhaust, Transmission | 40 | 01-11-2021 11:46 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Shorai Battery, Tender, and PTuning Tray | jack43 | Engine, Exhaust, Bolt-Ons | 4 | 08-23-2014 12:42 PM |
| Battery tray for Braille 21lb battery? | lordtakuban | Engine, Exhaust, Transmission | 4 | 09-10-2013 09:55 AM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 04:59 PM |
