Old 10-18-2016, 12:27 PM   #1
jeffsfrs
jeffsfrs's Avatar
Drives: 2013 FRS Whiteout
Angry clutch bearing issue
Hi
First off forgive me for not compleatly understanding posting a Q
My 2013 FRS has 63000 miles I had just taken it to dealer for fluids and check up , I drove a few hundred miles then noticed an odd sound from depressing the clutch. Today I took it to my mechanic who ownes a BRZ and he said its a throw out bearing , also he noted the clutch was adjusted too tight ( which could only of been done at the factory or dealer ) which he believes could of caused this issue. So now im looking at 7 hour repair to place a $ 25 part. I called toyota and they denied any known issue. I do not ride the clutch.
Does any one else know about this ?
Thanks
Jeff
jeffsfrs is offline   Reply With Quote
Old 10-18-2016, 12:38 PM   #2
gramicci101
Off Topic
The throwout bearing is a somewhat common problem on this car. One theory is that the shift fork flexes, causing premature wear and failure of the bearing. To fix this, Velox has made a nifty billet aluminum shift fork, and the responses from users are very positive.
http://www.ft86club.com/forums/showthread.php?t=96644
http://www.ft86club.com/forums/showthread.php?t=96974
Shift fork
http://www.ft86club.com/forums/showthread.php?t=104963
Old 10-18-2016, 12:39 PM   #3
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
My understanding is that the sound (if it's kinda like a squeak) is from lubricant or rubber seal getting rubbed off on the clutch pedal assembly or something - it shouldn't be the throw out bearing.
Pretty sure this is covered somewhere on the forum, and I think the member fixed it by applying grease to the fork or something like that. A design flaw, but not one which should cause mechanical issues. Mine had this at 72,000km, and I don't ride the clutch or do any silly things with it.
EDIT: Here you go
http://www.ft86club.com/forums/showthread.php?t=99578
http://www.ft86club.com/forums/showt...=56882&page=38
daiheadjai is offline   Reply With Quote
Old 10-18-2016, 12:51 PM   #4
SlammedSilly
Drives: 2015 Ultramarine FR-S
is your clutch pedal squeaking?
SlammedSilly is offline   Reply With Quote
Old 10-18-2016, 12:53 PM   #5
strat61caster
strat61caster's Avatar
Is the sound subtle or life disrupting?
If it's subtle then I'd leave it, most throwout bearings make noise as they age, especially if they're on the cheap end. You're out of powertrain warranty so I wouldn't expect Toyota to do anything for you, but it is a known issue. Leave it until the noise becomes more present and worrying. Throwout bearings rarely fail catastrophically, if yours was suspect it probably would have given out long ago.
http://www.ft86club.com/forums/showthread.php?t=52176
http://www.ft86club.com/forums/showthread.php?t=98247
http://www.ft86club.com/forums/showthread.php?t=21676
That's just what showed up in the first 4 google results, there's dozens more posts about it.
Edit: As above, squeaky pedal is a lack of lubrication, proper lubrication may involve the same amount of labor as replacing the throwout bearing requiring removal of the tranny.
7 hours is kind of a lot for a transmission removal from a professional shop, but it's not totally out of the ordinary.
ineedyourdiddly
Old 10-18-2016, 01:24 PM   #6
humfrz
Originally Posted by jeffsfrs View Post
Hi
Thanks
Jeff
I would suggest that you find the instructions on the forum for lubricating the clutch fork and take them to your BRZ mechanic friend and ask him to do the lubrication.......... you might get lucky and that will "fix" it.
humfrz
bearing, clutch
Repair shop in LA - Clutch Throw out bearing Octoman Southern California 18 09-06-2016 05:45 PM
Clutch Release Bearing Melted Haulin Engine, Exhaust, Transmission 37 05-29-2016 07:35 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 09:08 PM
bearing clutch burnt out . clutch squeals aagun Issues | Warranty | Recalls / TSB 18 07-21-2014 12:40 PM
FS: NJ O.E.M. Clutch, flywheel, throw out bearing Michaeljp92 Transmission and Driveline 9 02-04-2014 12:42 AM
