| Engine Swaps Discussion of engine swaps. |
Drives: Supercharged GT86
V8 plug and play ECU
Needing some help with ECU's for my 1UZ V8 swap
I know that the Motec is an ideal solution but it's just way out of budget I've been reading on here about various solutions: - Hydra EMS - Link - Haltech - Emtron KV8 Is there anything other than Motec that has the same function to run everything on the CANBUS? We already have a custom loom made up for the V8 but the issue is getting the car's electronics working obviously Last edited by smudge; 02-03-2018 at 07:21 AM. |
Drives: 2015 FRS
I emailed element tuning about the hydra. It seems like a great setup for me because I’m looking to do a LS3. Although after talking to them, this system will work with the LS1 and LS2, they just have to set the triggers in the EMS for the older style motors. I suggest calling/emailing them.
info@elementtuning.com tel(240)246.0302 |
#3 | |
I've contacted Phil through messenger as I've talked to him before about a few bits Also been reading that Emtron have developed something for the 86 and has a few 2JZ and LS swaps running on their KV8 system |
I Love custom Turbo kits
Drives: Limited BRZ
The options are detailed in this thread (they do need a bit of an updated but for the most part they’re still pretty accurate).
CAN Bus solution database (what works/what doesn't work) https://r.tapatalk.com/shareLink?sha...5&share_type=t There is no magical wand on this. If you want your setup to have everything to work like it was from factory, the only option is Motec from Pure Automotive. If you are willing to have a few systems not working, (e. g. traction control, (Motec does it better than the stock control), A/C, ABS, to name a few then you can select from any of the others that have the systems working you absolutely need.
#5 | |
I wish Motec was within my budget but I can't justify over £4k for it...especially when I'm not bothered about CC, TCS or A/C Think the Emtron might be a good middle ground for my application |
#6 | |
Drives: Toyota GT86
He made my CAN BUS translator for my 3UR swap. Great guy and very responsive. I don't think the 1UZ had CAN BUS so it should be much easier for him to convert analog signals to the FT86 CAN BUS IDs. He has all the required IDs for the BRZ/86 side to make all the following work: power steering, temp gauge, tachometer, and ABS. AC too even if you have the dual climate one. However cruise control and traction control don't work and I don't really care to be honest. Sent from my Pixel 2 XL using Tapatalk |
#7 | |
Yeah the 1UZ is a fairly simple engine, no CANBUS. And I'm the same as you, TC and CC aren't something that I need, more interested in having the full cluster working, ABS, power steering etc What ECU are you running with the 3UR? |
#8 | |
Drives: Toyota GT86
| Where to get plug and play HID | Burrcold | CANADA | 16 | 12-21-2016 03:45 PM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 11:53 AM |
| ECU Plug and Play | Mo707 | Engine, Exhaust, Transmission | 8 | 08-26-2012 12:21 PM |
| HID Plug 'n Play Kit | JW89225 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 07-31-2012 01:17 AM |
| Which hid plug n play kit? | huma | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-21-2012 12:10 AM |
