Old 02-28-2018, 10:01 PM   #1
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
10k miles between oil change
I decided to sacrifice my car (for science) and see how a UOA looks at 10k m.
I’ve always been a fan of Mobil 1, my last Miata was at 265k m before I sold it and still had great compression numbers.
I’m pleasantly surprised on how the FA20 with M1 did. Blackstone Labs even recommends stretching it out to 12k, which I probably won’t do and will go back to changing it every 8k again. It’s just nice to see that the oil is still healthy and doing it’s job beyond 10k m.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-28-2018, 10:12 PM   #2
Whiskerz
Drives: 2014 86 GTS
Good to know, thanks for sharing
Whiskerz is offline   Reply With Quote
Old 02-28-2018, 10:55 PM   #3
StraightOuttaCanadaEh
Wes
Wonder where all that magnesium is coming from
Instagram: @gt86ws
Old 02-28-2018, 11:21 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Oil additive in Mobil 1.
My ENEOS Sustina for comparison.
http://www.ft86club.com/forums/showp...5&postcount=77
I wanted to stretch mine to over 10k as well, but I simply was not putting enough "normal" miles on the engine.
Old 02-28-2018, 11:23 PM   #5
Somerandom18
Drives: 2017 manual BRZ
Impressed by the fuel percentage... Expected higher from a high compression engine. We have have some good rings.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-01-2018, 01:05 AM   #6
humfrz
Ahhhh.........go for 20,000 ...... for science .......
humfrz
Old 03-01-2018, 09:02 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Sure is an improvement over the EJ lol.
humfrz
Challenge accepted!
Current DD: M235i
Old 03-01-2018, 10:41 AM   #8
Mazikowski
Drives: 2013 GBS BRZ Limited
I stretched my last oil change out to 10k mi as well and got similar results. I'm planning on dialing it back to around 7.5-8k though since past that I saw a noticeable drop in fuel economy.
Here's the report with the numbers from my past few changes. All of these have been with Valvoline SynPower 0W-20, fwiw.
Mazikowski is offline   Reply With Quote
Old 03-01-2018, 03:50 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Very nice, thanks for sharing. I'm glad to see how great modern engines and oils are. That's why my mom's Porsche only requires 1 oil change a year.
Current DD: M235i
Old 03-01-2018, 11:05 PM   #10
OfficeWorker
Drives: 2018 WRX STI
Those look good!
OfficeWorker is offline   Reply With Quote
Old 03-02-2018, 12:09 AM   #11
Teseo
Drives: frs
Anyone have a report but with motul?
Old 03-02-2018, 07:34 AM   #12
Kaotic Lazagna
Drives: GR Corolla
I was changing mine every 15k with Amsoil and their oil filter. I'm dialing it back to 2k miles or less now since I don't daily it anymore.
Old 03-02-2018, 03:12 PM   #13
LOL I enjoyed the "keep up the good work" closing line. Like getting all As on a report card.
Old 03-02-2018, 04:27 PM   #14
Teseo
Drives: frs
Mate, thats is a overkill. If you use 0w-20 you are good, i would be worried about battery
how many miles before first oil change Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 72 10-25-2014 11:35 AM
Just purchased my '13 BRZ with 1,800 miles. Should I change the oil? torqueno Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 10-08-2014 11:55 PM
Oil change at 4100 miles djdrugga24 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2014 03:00 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 01:31 PM
Oil change at 1000 miles. Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 03-08-2013 05:18 PM
