Old 10-23-2018, 12:52 PM   #1
kamilehaula
Trunk button or fob trunk button aren't working.
Hello, as you may know, I'm a new member in this form here.
As my title says, can anyone help me out?
Thanks.
Sent from my CLT-L04 using Tapatalk
kamilehaula is offline   Reply With Quote
Old 10-23-2018, 12:54 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks.
Welcome to the forum.
If your trunk won't open, try the key in the trunk key-hole. The valet button, on the left side of the trunk, probably got pushed on accident.
Good luck.
I LIKE TIRES!
Old 10-23-2018, 01:02 PM   #3
kamilehaula
thanks for replying back to my post. My concern is to fix the issue and not use the key on the key hole in the back of my trunk. Would you know anyone that would have the parts to replace it and how much will it cost?
Thanks.
Old 10-23-2018, 01:05 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks.
Did you use the key? After you do, look at the left side of your trunk, your valet button has accidentally been pressed! Push it and it will fix the problem.
I LIKE TIRES!
Old 10-23-2018, 01:39 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Like said, check the valet button before thinking you need replacement parts.
Very common issue, searching helps using google.
Old 10-23-2018, 09:23 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Thanks.
Top tier attitude there.
I didn't read your post, but I don't want to do that thing you told me to do, instead I want to replace [something], can you tell me how much [something] will cost?
Something rolled in your trunk and pushed the opener cancel button.
But replace your button if that will make you feel better.
Old 10-24-2018, 12:03 AM   #7
humfrz
Thanks.
Welp, the fellows pretty much explained on what is going on here. Your manual also gives you some insight.
Now, I suggest you make a post and thank ol @Leonardo for his help. After you post at least 10 times, a "thanks" button will appear at the bottom of peoples posts, where you can thank them.
humfrz
Old 10-24-2018, 01:12 AM   #8
edwardl
Drives: 2018 BRZ
On my car I have to hold the trunk button/FOB button to open it. Just pushing it doesn't do it.
edwardl is offline   Reply With Quote
Old 10-24-2018, 03:03 AM   #9
humfrz
Good tip for a newbie -
How many out there remember when you got only two keys to a car - one opened the doors and trunk, the other turned the ignition on? In the dark you could tell because one key head was rounded and the other was angular.
Back then we didn't have to:
* worry about FOB batteries running low
* wonder which FOB button to push to do what
* worry about a spare; the second set was simply wired up under the car
* be concerned about someone remotely skimming your FOB signal
* didn't have to pay the dealer hundreds of dollars for a spare key
* be annoyed by a big bulky thing in your pocket; just two small keys on a key chain
* by the time the keys wore out, it didn't matter because the lock was so worn that you could use a bent 8 penny nail to turn it
* what did I miss -
humfrz - stuck in the 50s
Old 10-24-2018, 03:22 AM   #10
86MLR
86MLR's Avatar
Climb in from the back seat and have a look if all else fails.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 10-24-2018, 08:33 AM   #11
nitro_alltrac
nitro_alltrac's Avatar
Drives: '17 86
[QUOTE=humfrz;3147693]
* what did I miss -
humfrz - stuck in the 50s[/QUOTE
Oh yeah. Remember those days well!
nitro_alltrac is offline   Reply With Quote
OEM illuminated trunk release button Guillaume Cosmetic Modification (Interior/Exterior/Lighting) 43 01-10-2018 06:02 PM
BRZ Key Fob trunk button Jarrid'sBRZ BRZ First-Gen (2012+) — General Topics 26 06-03-2016 02:50 PM
DIY: Trunk lid button for use with Easygo kit Chaetagnath DIY (Do-It-Yourself) Guides 1 08-03-2015 04:51 PM
Trunk opener button fitcious Scion FR-S / Toyota 86 GT86 General Forum 13 05-13-2014 02:24 AM
Trunk button not working Jahdai42 Issues | Warranty | Recalls / TSB 4 02-19-2013 09:03 AM
