Old 08-07-2019, 08:46 PM   #1
jslack
Drives: 2017 Red subaru BRZ Limited
Abs and traction light activating on hard turn
Hi group. Hoping you can help me out. I recently just added a new front and rear sway bar, front ends links and rear lower control arms. As soon as I got done with it the abs and tcs light activate when going around curves mainly going over 50 mph. I didn’t like the feel of the rear sway bar and removed that but the car does seem to still activate the abs and tcs when driving. Could I have done something to an abs sensor? I also have 17 BRZ and I did have to disconnect the hi low level sensor to replace the lca’s. Could that have caused the issue too? Thanks for any help guys.
jslack is offline   Reply With Quote
Old 08-07-2019, 08:48 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
How sharp a turn are you talking? Are you lifting a wheel? Are you turning too hard for the speed and angle of the turn?
Old 08-07-2019, 10:00 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
what are your tire pressures?
Old 08-07-2019, 10:52 PM   #4
rawbeanz
Drives: 2015 Subaru BRZ
alignment?
My traction control and ABS lights stay lit after I just did my coilover & LCA install. Then I read the link below and I'm thinking it might be the alignment. I'm taking it to the shop next week.
https://www.ft86club.com/forums/showthread.php?t=128822
rawbeanz is offline   Reply With Quote
Old 08-07-2019, 10:55 PM   #5
Decep
Drives: 2013 FR-S Series 10
Rear lower control arms -> did you get an alignment? I bet your alignment is way off.
Old 08-07-2019, 11:14 PM   #6
jslack
Sorry I forgot to add information. I had my car aligned the next day. The one issue they had with the alignment is the toe for the rear. It’s at -1 degree on each side. I’ll aoon be getting adjustable toe arms. So couple that be the issue? The curves are any curvy highway or back road where I can take the curve around 55 mph. There was never an issue before the installs. Tire pressure is good and don’t think any tire is lifting. It never was before. Thanks group
Old 08-07-2019, 11:45 PM   #7
ls1ac
ls1ac's Avatar
have you tried pushing the sport button? does it change the way the lights come on?
Old 08-08-2019, 12:31 AM   #8
maslin
Benz Tech
Drives: 2017 BRZ Premium
-2* of rear toe? That’s a lot of toe out, a whole lot. How low is the car? I’m on Eibach Pro Kits and had no problem bringing the toe in. Something else is going on, or you’re tucking rim.
maslin is offline   Reply With Quote
Old 08-08-2019, 12:40 AM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This may be from a wheel lifting if you've made the suspension too tight. I don't see how you could 3 wheel if there's no bump or change in slope between L/R that only affects one side before the other.
This happens in my car when I pull onto the main road. There's a severe change in grade, so the left wheel climbs the grade but the right wheel hasn't met it, and lifts off the ground. TC comes on if I don't have it disabled every time.
Old 08-08-2019, 01:00 AM   #10
norcalpb
norcalpb's Avatar
You could try to see if this black/white wire is damaged (wheel speed sensor)
Old 08-08-2019, 01:46 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Not performed alignment after suspension install work & -1 degree toe-out rear each side most probable culprit. Toe-in stabilizes that car end where it is, toe-out - does opposite. And whole degree is 10x more then there should be, for toe.
Toe is like presteered wheel to/from centerline. When in turn you lean more on outside tire, and it is pre-steered out, of course that end will try to rotate more.
Old 08-08-2019, 06:29 AM   #12
jslack
Thanks for the input. It’s at 1 degree on each side. I do have some adjustable toe ends coming. To correct. The car is lowered about 1.5 inches in the front and back on coil overs. I’m beginning to think the toe might be the culprit. I’ll have to see after I can get those one and get the adjustment again.
Old 08-08-2019, 06:59 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
1 degree toe is a LOT. After all, it's adjustment usually is about 0.00-0.20 max, more often just about 0.1 of degree (where camber tenfold difference of 0.5-1 degree one might not even felt if not pushing it a lot). And if toe is off by such large extent, obviously it's impact on handling will be that much greater, either car end not willing to turn much if toe-in, or very zealous to push that end out. And of course lot of toe-wear, as with high toe (no matter in or out) wheels are presteered all the time and are dragged slightly sideways even when going in straight line.
Moral of story: if you change suspension parts or their settings do proper alignment afterwards. Nothing wrong with car, just one important work not yet done.
Old 08-08-2019, 01:12 PM   #14
finch1750
finch1750's Avatar
That seems strange. I have been much lower (along with many others) and OEM toe arms are plenty of adjustment. Any damage in the rear?
Got a pic of the alignment sheet? And is it a performance alignment shop or just your local chain?
NRG Hub hard to turn? Scjacob827 Cosmetic Modification (Interior/Exterior/Lighting) 10 10-18-2019 12:44 PM
Traction Control activating in track mode imprezive Software Tuning 2 07-21-2019 07:16 AM
Traction control activating in 3rd and 4th gear... JBezugs Issues | Warranty | Recalls / TSB 5 11-01-2017 12:27 PM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 02:04 PM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 05:08 PM
