'17+ stock headers vs aftermarket catted headers
Doing some searching and not seeing much consensus as to whether there's any real benefit to adding a header (if it's going to be catted) in place of the stock '17+ header as apparently they were opened up in the refresh.
Looking for a small bump in power, and to be able to run OFT stage 2, but not sure if adding a header is going to be any better than stock in this case. (only considering catted header as I'm not looking to run into any emissions testing issues) Thanks in advance for any help on this. |
Drives: 2018 BRZ
From my (limited) understanding, the real gain in flattening the torque dip (and a mild boost in overall power) is from removing the cat, not from the tune alone. So I would guess that a catted header wouldn't provide as much benefit as a catless header (or maybe none at all for 2017+).
Drives: '15 BRZ RA
A good aftermarket catted header would have a small advantage, because it is using a sport cat. Meaning a cat will less cells.
Drives: 2013 frs red
Probably no real advantage with an aftermarket catted header. Catless would help. Tune it and enjoy it. Keep it clean and as stock as possible so you can move it when you want a faster car.
Ok, but given there's little difference between the stock '17+ cat and an aftermarket one, would I be ok to move to OFT stage 2 with what i've got stock?
TRACKBREAD
Honestly if you want to stay catted on a facelift car, get a flex fuel tune and run E85. torque dip will be gone.
TRACKBREAD
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Go drive someone’s 13-16 twin with a catless header and compare to your car. Only way you will really know.
My 16 is jdl catless header, jdl FP catted and resonated, drop in filter and Crawford powrblocks with OFT stage 2 plus tune. It is significantly better than stock, but nothing like the bump going to stage 2 on my WRX. Still worth it. |
#10 | |
#11 |
#12 |
Not worth it. Only reason if you wanted uel for a different sound.
2013 Series 10 FRS #553
#13 |
TRACKBREAD
I'm firmly in this camp now too. Once you learn to drive around the torque dip, it's a non-issue. I went from stock > UEL > UEL+FP > UEL+FP+E85 > Stock header/fp + catback. The catback was worth it for the sound. Everything else, even the E85 didn't make a great difference in the higher rev ranges, not for the money spent at least.
#14 |
Drives: 17 Asphalt 86
You will get some power, but sound should be the main goal for that setup.
It allows you to run pretty much any catback without being obnoxiously loud. |
| Catted Headers | EN2_Squirrel | Engine, Exhaust, Transmission | 53 | 12-16-2016 10:52 PM |
| WTB UEL Catted Headers | LastRep | Canada Classifieds | 0 | 08-08-2016 12:51 PM |
| WTB catted uel headers | Legionsk88 | Want-To-Buy Requests | 0 | 04-21-2016 08:48 PM |
| OFT with Catted headers | DarkestBuddha | Software Tuning | 6 | 10-14-2014 11:51 AM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 01:29 PM |
