Old 12-31-2020, 11:33 AM   #1
Nonstopper0
Nonstopper0's Avatar
Drives: 2013 Grey Varis Widebody FR-S
Need help with my Coilover Situation (HKS Hypermax IV)
So I was having ALOT of clunking issues with my front suspension all around so I decided to just take everything apart and go from there. (I also snapped a top hat bolt while making sure everything was tight)
I took my HKS Hypermax IV struts off to find that the top hat where i also seared the bolts bearing (drivers side) was bad. It was having alot of trouble moving the coil around on the bearing yet the passenger side top hat moved around without alot of effort. (Im guessing the resistance to move means its blown and could cause clunking)
I have contacted: Evasive Motorsports, HKS Japan (kinda, very hard to contact them), and Vivid Racing.
None of these companies could or even bothered to help me out on this and im at a loss. I want to just buy new top hats but i'm not sure what will fit and what wont with these struts.
Does anyone have experience with this ?
(This one seems to be just fine)
(This one seems to have a bad bearing)
Probably Doing some Ricey things.
Nonstopper0 is offline   Reply With Quote
Old 12-31-2020, 11:44 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Need to measure the shaft diameter(where the nut screws on) and the bushing and I would correlated it to Raceseng's chart to see what top hats are interchangeable.
https://raceseng.com/media/pdf/casca...ck-fitment.pdf
They also have this if you are interested in purchasing their top hats.
https://raceseng.com/media/pdf/races...iloverform.pdf
Old 01-03-2021, 09:19 PM   #3
Z06ZN6
Drives: 2017 Toyota 86
Did you try to contact HKS USA? support@hksusa.com.
Another option if you are unable to rebuild it yourself would be to take it to a local machine shop. Once the parts are pressed out and measured, replacements can be ordered from a supplier like aurora or somewhere else and pressed back in.
Z06ZN6 is offline   Reply With Quote
Old 01-04-2021, 07:27 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You could pull the pillowball out and try to source it. I be it presses out the bottom of that housing.
https://www.pegasusautoracing.com/pr...QaAuxAEALw_wcB
https://www.mcmaster.com/63195K18/
Old 01-04-2021, 07:59 PM   #5
Have you tried contacting your Vendor? They should be the ones helping you, not Evasive, HKS Japan, or Vivid.
HKS USA would be your secondary source of support.
If you bought these used, caveat emptor.
Replace the broken/worn parts. If replacements are not available, then you may need to get new coilovers to eliminate the noise.
Old 01-05-2021, 04:49 PM   #6
Nonstopper0
HKS USA was completely unable to help in any way and directed me back to a vender. Who were also unable to help.
I think I am just going to switch brands if it is really this hard to get a miniscule amount of customer service from them.
These were not used but they are very old. Probably the first generation they came out with.
Old 01-05-2021, 08:04 PM   #7
norcalpb
norcalpb's Avatar
In my experience bearings/ball joints are really hard to move around when new, and super easy to move when blown. Unless of course one is seized because of how old your coils are.
Try grabbing the coil assembly by the top hat and shake it up and down. Is there play/does it clunk?
It will cost you about $200 to service those top hats for parts and labor (more than likely get nicer bearings from like FK), which is the option I’d do after exhausting the warranty option which it kinda sounds like you have.
Old 01-06-2021, 03:40 PM   #8
Your loose bearing is the issue. Try McMaster Carr.
And yes, support is king.
Old 01-13-2021, 02:21 PM   #9
Nonstopper0
Hello everyone, Noob question.
How do I actually measure the size of the bolt on the damper so i can buy another set of top hats? I'm used to just going to ACE hardware for smaller bolts but they wont have anything that size
Old 01-13-2021, 10:00 PM   #10
Z06ZN6
They're Japanese parts so they'll be in the Metric system. To measure a metric bolt, first simply measure the bolts outside diameter ( the threaded portion, or the shank) in millimeters. The center shaft threads are probably 12mm so in that case it would be an M12 bolt (double check because I didn't actually measure it). Then measure the distance from one thread to another (the thread pitch) in millimeters. As an example, it may be something like 1.25 or 1.5mm, etc. So an example bolt would be a M12x1.25. After that, the length of the bolt is appended in millimeters such as 15, 20, 25, etc. For a typical bolt like a hex or socket head cap screw, that's measured from under the bolt head to the lther end of the bolt. For a flat head (countersink) its measured as the entire length of the screw. Google measuring metric bolts. Its not hard. Good luck.
Old 01-13-2021, 10:00 PM   #11
Z06ZN6
Here's a simple guide...
https://www.pro-bolt.com/bolt-measuring-guide/
bad bearing, bearing, coilover, hks hypermax iv, top hat
Used HKS HyperMax IV GT coilover *sold* Pekingduck Brakes, Suspension, Chassis 0 12-30-2018 01:43 AM
Used HKS HyperMax IV GT coilover *price drop* Pekingduck Brakes, Suspension, Chassis 11 09-12-2017 12:09 AM
FS:Brand New In Box HKS HyperMax 4 SP Coilover Kit523 Brakes, Suspension, Chassis 0 10-28-2015 03:26 PM
Coilover situation advice? Kerune Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-05-2015 09:20 PM
My situation MR WHAAKAKA Scion FR-S / Toyota 86 GT86 General Forum 31 05-22-2013 04:14 PM
