Old 08-04-2015, 10:40 PM   #1
Kerune
Kerune's Avatar
Drives: Lexus RC-F
Coilover situation advice?
Hello ft86,
Update: Going to The Racer's Line to swap into Teins and will fix the B14s to be serviced or sold.
Kerune is offline   Reply With Quote
Old 08-04-2015, 10:48 PM   #2
swarb
Don't drive with the clunk. You will damage other, much more expensive parts.
Borrow/rent a spring compressor from local parts store.
Put stock back in for now.
Pull the damaged parts off and decide what to do from there.
Re-thread/chase the threads with a die, or make slightly smaller and use a smaller nut.
Or send them in to get replaced.
So what was your mistake? and what did you learn from it?
Old 08-04-2015, 10:52 PM   #3
mush
mush's Avatar
ur suppose to use a pass through socket and a hex tool to put on the top hat
Old 08-04-2015, 10:55 PM   #4
kodyo
Drives: Scion FR-S
Are you trying to put OEM suspension back in or OEM strut back on a spring? You obviously don't need a compressor to put an already assembled OEM strut assembly back into the car. Either way, you can rent a mcpherson strut compressor at Oreileys for free.
Also, wouldn't an impact gun spin the whole top part of the strut? I know the OEM ones have a female hex so you can hold the strut still while you tighten the top nut. Do it that way next time.
kodyo is offline   Reply With Quote
Old 08-04-2015, 11:49 PM   #5
Teseo
Drives: frs
Dont forget to beat the hell out of your friend
Old 08-05-2015, 12:17 AM   #6
kodyo
Drives: Scion FR-S
OP, if you need OEM top hats, send me a PM. I have a few I can sell you for cheap (basically cover shipping) if you don't want to bother removing the ones you have installed.
Old 08-05-2015, 12:58 AM   #7
Kerune
Kerune's Avatar
Drives: Lexus RC-F
Hey, thanks! That would be great, but I'm frustrated with the situation (our schedules are not working out) and I'm treating this as urgent, I've hit up Racers Line in an attempt to buy new coils and swap from Bilsteins to new ones, then leave the B14s assembled for selling or worked on by Bilstein.
If this goes through, it will be for sale for anyone interested and you could do the Bilstein service yourself or thread it yourself and will be priced reasonably. :/
Thanks fellas, I have learned my lesson. Not taking any easy routes and apparently be skeptical with people's skill level -_-
Old 08-05-2015, 09:03 AM   #8
kodyo
Drives: Scion FR-S
Don't beat yourself up. I broke one of my OEM struts this weekend trying to take the easy route while installing camber plates. Had to get a local members struts to finish the job.
If you need the top hats, just PM me, but sounds like you've got it worked out.
Old 08-05-2015, 09:20 PM   #9
burdickjp
Drives: 2013 ultramarine Scion FR-S
I'm interested in the Bilsteins.
burdickjp is offline   Reply With Quote
Looking for a new coilover .Need some advice mrharry Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-16-2014 08:47 AM
Need Coilover Advice Please distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 03-07-2014 06:43 PM
Need a little advice on coilover install swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2014 11:00 PM
STX Coilover Advice ubersoph Tracking / Autocross / HPDE / Drifting 30 11-01-2013 08:34 PM
Spring/Coilover advice canuckbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-16-2013 08:09 PM
