Old 05-15-2021, 08:12 PM   #1
Muckraker
Drives: 2014 FR-S
Problem: Key fob and dashboard trunk button intermittently don't work
My 2014 FR-S has started having an odd problem - can anyone offer advice?
The electronics that unlock the doors and open the trunk are intermittently not working.
At first I thought it was a dying battery in the key fob, but the dashboard button to open the trunk also did not work at the same time the car wouldn't respond to the fob.
The trunk button and the fob started working again after I put the key in the ignition and turned it to the on position.
It doesn't happen every day. I think in the past two weeks it has happened twice, maybe three times.
Muckraker is offline   Reply With Quote
Old 05-16-2021, 01:48 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
is it consistent that when it doesn't work, both refuse to work during that time?
try checking fuses first, as turning the car on enables other electrical circuits to turn on which could be bypassing a problem fuse.
just be sure to check that nothing's resting against the valet button in the trunk-- i believe that would disable both remote buttons.
otherwise, it could be the trunk solenoid starting to fail, which isn't too hard to change.
Old 05-25-2021, 08:00 PM   #3
Bman117
Drives: Waiting on 2nd Gen!
Sounds silly, but have you changed the keyfob battery? When it gets low, around 3.05 or below it can act strange.
Bman117 is offline   Reply With Quote
Old 05-26-2021, 04:11 PM   #4
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
It's easy enough to engage/disengage the valet button in the trunk several times to make sure age/corrosion/dirt haven't come into play as it mostly goes unused (except when inadvertently pressed by shifting cargo!).
tarzan_nojane is offline   Reply With Quote
Old 05-26-2021, 07:05 PM   #5
TAKECLEAR_86
TAKECLEAR_86's Avatar
Drives: 2017 Toyota 86 Halo
Had the same issue when I first got my car, ended up just being the Keyfob needing a new battery.
TAKECLEAR_86 is offline   Reply With Quote
Old 06-07-2021, 12:13 PM   #6
Muckraker
Drives: 2014 FR-S
Based on both the fob and the dashboard trunk button failing (if it were the fob battery, the dashboard trunk button would be unaffected), and the intermittent nature of the problem, my brother (former auto mechanic) suspects the problem is in the electronics that handle the electric door locks and the electric trunk release.
His theory is that solder traces/joints in the electronics are developing cracks.
The car is 7 years old, daily driver. Things break over time.
To be continued...
Old 06-07-2021, 01:03 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@Muckraker
Are there any other strong signals close by that are transmitting, and possibly interfering with your keyless operation? For example: Are you only having this issue in one area, or does it also happen when you.....say.....make a run to the grocery store or to fuel up or.....?
Is there anything inside your vehicle that is transmitting a signal that you can remove or power down temporarily to test this theory?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 06-07-2021, 01:25 PM   #8
To be continued...
You didn't answer the question. Have you at least tried replacing the fob battery? You could have two separate issues going on and for a couple of dollars you could eliminate the possibility of one.
Old 06-07-2021, 11:33 PM   #9
soundman98
soundman98's Avatar
To be continued...
considering that it seems that your problem is somewhat a lone duckling, being that very few others are complaining about similar issues, i would say that while cracked or damaged circuit boards are possible, it's quite a distant possibility. damaged circuit boards generally have external factors involved in the damage. generally, i've only seen it on 15+ year old vehicles, and usually in cases where the circuit boards are improperly mounted, exposed to the elements, or subject to extreme heat cycling. none of which should really be the case in these cars.
is this mostly happening at your home? check if led light bulbs are on. many cheaper models emit enough EMI to mess up the thought process of passing geese flocks...
Old 06-08-2021, 01:19 AM   #10
soundman98
soundman98's Avatar
The first thing I would look into is if the valet button is being bumped by something in the trunk.
The second thing would be batteries.
And the third would be the trunk popping solenoid
fob, key, trunk
Trunk button or fob trunk button aren't working. kamilehaula Issues | Warranty | Recalls / TSB 10 10-24-2018 08:33 AM
Driver side trunk button doesn't work. Aphaux Issues | Warranty | Recalls / TSB 25 07-29-2016 02:55 AM
How does this button work!? Zardoman BRZ First-Gen (2012+) — General Topics 11 10-02-2015 08:02 AM
'Brake' dashboard light comes on intermittently speedy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-27-2015 10:35 PM
dashboard blank button replacement question relaxjim Hawaii 2 11-24-2014 04:52 PM
