Old 04-09-2022, 12:10 AM   #1
repillows
Drives: 2013 Scion Frs
FRS Shifter issue
So I just recently purchased an FRS with a manual transmission with 145,000 miles and noticed that it is very difficult to move the gear towards the left side to get into first gear or second gear. I would have to try multiple attempts to move it left and the easiest way to get into first gear is by going from 2nd to 1st gear when I’m able to move it left. Moving the gear lever towards the right hand side shows no problem. I can go through every single gear including reverse without an issue apart from first gear and second gear. There is also an issue where whatever gear I’m in, there is a lot of play from side to side. Granted, when I get the car driving there is no issue with the transmission itself. Anybody have these issues before? Thanks!
repillows is offline   Reply With Quote
Old 04-09-2022, 04:21 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Many, many people ignore the need to properly adjust the top plate when installing the shift lever. The reverse lockout foot rides along a boss on the plate which is intended to center the shift mechanism in the first and second gear gates.
Look in my sig line for a link to the service manuals. Browse a little through the menu tree and you'll find the alignment procedure.
Old 04-09-2022, 11:06 AM   #3
repillows
I bought the vehicle with about 145,000 miles and it’s the original manual transmission. As far as I’m concerned, I don’t think the shift lever or anything like that has been touched. Can I still try this procedure out?
Old 04-09-2022, 03:19 PM   #4
Ultramaroon
not playing cards
On re-reading, I think bushings on your gearshift linkage are worn. The lever should not be able to rotate about the vertical axis at all. The other symptom is also difficulty finding the first and second gear gates because the gearshift needs to be angled further to the left to take up the slack.
Search for the first and second gear gates while lifting the reverse lockout. If they're easy to find that way, you have your answer. Thankfully, it's all external to the transmission and easy to spruce up. Also, the adjustment is easy enough to fudge without feeler gauges. Loosen the plate and adjust it with the gearshift centered in both first and second gear gates. Just takes a gentle touch to get it right.
Old 04-09-2022, 06:27 PM   #5
repillows
I was able to fix it by adjusting the reverse lock out plate. I found out that the clutch was replaced so it had been messed with. All is well for going into gear! Now I have more things to tackle with my front suspension and alignment! Lol
Old 04-09-2022, 07:52 PM   #6
Ultramaroon
not playing cards
Well done.
IRP shifter issue redlined600 Engine, Exhaust, Transmission 13 02-26-2019 10:28 PM
Different trans issue re:shifter centering Bent42 Engine, Exhaust, Transmission 1 04-12-2018 01:39 AM
forks in shifter issue Flame9020 Issues | Warranty | Recalls / TSB 16 02-18-2017 04:42 PM
shifter issue srgssgtmatt Issues | Warranty | Recalls / TSB 5 09-15-2016 03:01 PM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 06:10 PM
