Old 08-20-2012, 10:22 AM   #1
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Brake fluid volume
Anyone know how much fluid needs to be pumped through the system to replace it all?
This is the one reason I can think of to use ATE Super Blue (and why a lot of people use it). When the fluid coming out is blue, you are done. The next time you bleed the brakes go to amber color, and when the blue is gone you are done.
celica73 is offline   Reply With Quote
Old 08-20-2012, 03:05 PM   #2
CSG David
CSG David's Avatar
If you are incredibly efficient, you can run through 500mL. Otherwise, you can be incredibly thorough and run nearly 1L to clear out the lines completely. Gravity bleed with some vacuum per corner will help you out if you can't someone to pump the brakes for you.
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
Fluctuating volume so26 Issues | Warranty | Recalls / TSB 9 08-16-2012 01:26 AM
2006 Acura TL Minor Paint Correction ( volume vs quality ) OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-06-2012 07:23 PM
Volume of spare tire well? djliquidsteele Electronics | Audio | NAV | Infotainment 1 06-18-2012 01:22 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
