CANADA Canada
Old 11-24-2022, 11:12 AM   #1
ClaytonG
Drives: Car Enthusiast trying to learn more
Post Aftermarket headers in Ontario
I've finally figured out how I should plan my dream car in regard to performance parts but I am still fairly new to cars and don't know the ins and out
Upgraded suspension and a head package and cams for the FA20 particularly FBM Fa20 Stage 2 Head Package and Full Blown Stage 1 FA20 is my first priority
The next part I would want would be the headers since they seem to be a good next step in upgrading performance. Then I will start to look at exhaust after
However, the exhaust may be 1st because I have a question regarding the headers and
I read that catless headers or performance headers affect emissions tests but if I go with catless headers can I still put a cat-back exhaust without failing a test?
I want my car one day to have a bit of power behind it while still adhering to the laws as closely as I can without breaking them but I might make some exceptions if there is a way to not fail the emissions test. Rather not get a fine or car towed or something
Any insight will be much appreciated.
ClaytonG is offline   Reply With Quote
Old 11-24-2022, 11:38 AM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
The two oxygen sensors are before and after the cat so going to a catless header will require you to re-tune the ECM and surely would fail an e-test if we still had them in Ontario.
A retune will also help maximize any power gains offered by the header.
That said, your cars exhaust will be stinky without a cat whether it is part of the header or downstream in an after-market exhaust system.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 12-17-2022, 01:12 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Aftermarket headers with tuning will disable the catalyst efficiency codes related to non OEM type cats which would fail an emission readiness check. That was the last system used when emission testing was done in Ontario.
Retaining OEM front pipe or a front pipe with a cat will keep the smell in check. Deleting the header cat does add a bit of smell, but no where near as bad as being full catless.
As far as the build goes, it makes more sense to start with common mods first, and decide whether engine work is worth the $$. You will get more power from header tune than you will with the head package. Header tune is noticeable but not a massive difference which might give you an idea if it's worth spending many more thousands for something you may not even feel on the street.
Old 04-05-2023, 09:08 PM   #4
wparsons
wparsons's Avatar
There's no regular emissions tests in Ontario any more, but if you're stopped by the MTO (or a cop that calls in the MTO) they can do a roadside sniffer test in addition to a visual inspection and fine you for removing emissions equipment. If you keep a cat in the front pipe you're less likely to be noticed because it'll keep it from smelling like you're catless, but if they look at the header and notice there's no cat there you can still be fined. Technically you can even be fined for replacing a stock cat with a high flow one, but if there's a cat where there's supposed to be I doubt any officers would notice if it's stock vs aftermarket.
flickr
aftermarket exhaust, emissions test, headers
'17+ stock headers vs aftermarket catted headers ThatYeti Engine, Exhaust, Transmission 17 05-21-2020 12:18 PM
WTB Aftermarket headers Stats Want-To-Buy Requests 0 05-26-2019 05:14 PM
Looking for any aftermarket headers Easy Mid-Atlantic 11 05-24-2015 09:36 PM
Aftermarket headers in Ontario Mr.Impreza CANADA 22 05-02-2015 12:42 PM
WTB aftermarket Headers Nitro_FRS Engine, Exhaust, Bolt-Ons 5 01-09-2014 03:07 AM
