Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Headlight elimination
Hello,
Did anyone eliminate headlights for weight saving? If so, how? Gutting ir or removing and creating a cover? Thanks |
Rust bucket enthusiast
It's pretty easy to disassemble the headlights. Bake for 10-15 minutes at 220f.
From there, carefully peel the clear headlight lens from the body (or don't be, if you're removing alllllll the internals). You could just rip everything out, reseal the headlights and be done. I think if this is for weight savings, your best bet is NASCAR mode; just sheet metal cover the openings after you remove the headlights.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Thanks a lot. Will try and report back
In the end, a colleague used the headlight as mold for a fiberglass version, basically eliminating 8lbs per side.
Neat! What other extremes have you gone to for weight reduction? This is cool stuff. Give us some pics!
This is a friend’s car that I help. Right now car is about 2700lbs with driver and full cage.
Fully gutted, spl arms everywhere, dremel anything that does not appear to be structural including door bars (cage with nascar side protection), no AC, catless header, muffles steel exhaust (needs to meet noise level, so I do not think a tomei would work and don’t eanna risk that money). I was bummed that after discussing here, i was not able to go and help on the headlight as would be nice to learn. But he has a time constraint and needed to complete it soon. For next year (I think he is 3x T3 champ with this car already), I think priority will be improving suspension and traction (looses traction on right hand turns with small bumps). I have a fun and easy work, need to develop ideas and work on a car. Taking all this experience and will do the same when I complete mine (so far, mine were always track cars, no race cars so far). |
#7 | |
Objective is 2640lbs, we will get there.
Pics
Pictures
| First only left headlight works, then only right headlight | russsak | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-23-2020 04:05 PM |
| Cold Start laud valve overlap elimination. | Cycletech | Software Tuning | 1 | 09-21-2017 12:53 AM |
| BRZ headlight shroud inside FRS headlight? | S84kam | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-02-2016 01:24 AM |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
| TRS headlight mod | RRnold | Other Vehicles & General Automotive Discussions | 0 | 12-24-2011 05:20 PM |
