Old 09-30-2012, 06:01 PM   #1
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
Paddle Shifters
is it annoying to have the paddles on the steering wheel rather than the column?
seems like if you just made a turn, you have to straighten out your wheel to shift.
also, can you hold the rpm's without it shifting by itself in sport mode? or do you have to turn everything off?
thanks
Atticus808 is offline   Reply With Quote
Old 09-30-2012, 06:47 PM   #2
ike44
Drives: Whiteout FRS
Sometimes the paddles are a bit awkward to hit when the steering wheel is turned 90 degrees in a direction, but I suppose they work fine where they are.
The car will shift for you if it notices that you are going to try to redline it in like first gear or something so that you dont do any damage. It will also shift down for you if the rpms get well below 1000 so that it doesnt stall or flood or something.
ike44 is offline   Reply With Quote
Old 09-30-2012, 11:35 PM   #3
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
No it's not bad because you can use the slap stick for things like that. I only uses paddles on straightaways or so when i just wanna hear my car
Obja is offline   Reply With Quote
Old 09-30-2012, 11:37 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
thanks
using proper driving styles, you should already be in the gear you need to before the turn, sifting on the exit and your steering wheel should be straight enough to execute a correct shift
to hold rpms, put the selector in "M" mode, no you dont have to turn everything off
i have yet to see my car shift for me when i want to hold it in 1st gear... lol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 09-30-2012, 11:46 PM   #5
Obja
Obja's Avatar
^^^ SAME. it has not shifted for me yet, or maybe i thought it was me but it was doing it automatically....
Old 10-01-2012, 03:53 PM   #6
Assuming you are talking manual mode, it will not shift up a gear unless you do it.
I believe what was being referred to is down-shifting. The 6AT will not let you downshift into an over-rev situation. So, if you're close to redline in second you can't downshift to first.
Old 10-01-2012, 06:14 PM   #7
Atticus808
Atticus808's Avatar
but you can hold the second gear at red line if you want to?
Old 10-01-2012, 06:30 PM   #8
Karl07
Drives: 2012 86 GTS - Storm Black
You can bounce it off the limiter all day if you want. I accidentally forgot to shift in the demo car as I was too busy enjoying the handling...whoops.
Karl07 is offline   Reply With Quote
Old 10-01-2012, 09:34 PM   #9
In any gear actually. The AT will only prevent a change if you will go over redline, or force a change down if you are going so slow the car would stall (driving in 6th car at 5MPH for example).
When the 1st86 were in CA, and I test drove it, I kept getting the paddles "backwards" in manual. I downshifted several times when I meant to upshift, so I learned early on what it would do. The "ride along" from Scion kept giving me the evil eye..
paddle shifters Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 11 08-28-2012 11:15 PM
Paddle Shifting switchkick Scion FR-S / Toyota 86 GT86 General Forum 13 08-14-2012 04:29 PM
Can you manually shift automatic version w/out the paddle shifters? maxeveland Scion FR-S / Toyota 86 GT86 General Forum 31 02-01-2012 12:51 PM
Paddle-Shifters Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 45 09-14-2011 01:20 AM
6MT vs Paddle shiftting Auto Dragonitti Scion FR-S / Toyota 86 GT86 General Forum 149 07-03-2011 01:20 AM
