Old 10-27-2012, 01:31 AM   #1
FRS_13
Drives: 2013 Scion fr-s
Exclamation Lowering springs HELP
Hello im in need of lowering spring im going to sema sunday but i need lowering springs any suggestion i need help i stay torrance 90501 thanks
FRS_13 is offline   Reply With Quote
Old 10-27-2012, 01:36 AM   #2
gmookher
I just put on the h&r supersports...couldnt be happier
quality german stuff
gmookher is offline   Reply With Quote
Old 10-27-2012, 01:46 AM   #3
FRS_13
need help i need them by tomorrow are they hard to put on
Old 10-27-2012, 02:06 AM   #4
Le86
Drives: Asphalt FR-S
If you're somewhat mechanically inclined, it won't be an issue for you at all. You can go to your local parts store and rent a spring compressor to remove/install the springs. I believe there is a spring install DYI somewhere on here. I'll try to search it up in a bit when I sober up...
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-27-2012, 02:37 AM   #5
FRS_13
thanks but i need springs
Old 10-27-2012, 02:42 AM   #6
gmookher
tire rack, overnight?
I know Perrin has them in stock
Old 10-27-2012, 02:42 AM   #7
Le86
There are plenty up for sale. Find one in your area or I'm sure plenty of distributors here will ship overnight.
Vendor: http://www.ft86club.com/forums/forumdisplay.php?f=48
Member: http://www.ft86club.com/forums/forumdisplay.php?f=63
Old 10-27-2012, 02:59 AM   #8
whataboutbob
AutoX-10/10ths every run
Why you procrastinate?
Build thread:Here
Old 10-27-2012, 10:36 PM   #9
Le86
Old 10-27-2012, 11:03 PM   #10
EN2_Squirrel
EN2_Squirrel's Avatar
x2
EN2_Squirrel is offline   Reply With Quote
FS: NEW Mach V Lowering Springs M1K3 Brakes, Suspension, Chassis 4 11-09-2012 06:19 PM
Coilovers or lowering springs Hawk77FT AUSTRALIA 9 07-30-2012 10:41 PM
TUV approved lowering springs. Who has them? Scotty Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-10-2012 02:45 PM
Will US spec lowering springs for the FR-S fit on our 86 in Aus? leej AUSTRALIA 7 07-08-2012 05:24 AM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-11-2012 12:36 AM
