Old 12-05-2012, 03:36 PM   #1
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Question on drilling new holes
So im dead set on getting enkei rpf1's on my FRS. The size i want is either 17" or 18" and 9" wide. The issue is they dont make our bolt pattern for this size. A friend told me that I could take the wheels to a local shop and have them drill new holes so in total i will have 5x100 and 5x114. My question is will this cause any issue with the wheel?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 12-05-2012, 03:40 PM   #2
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I'm pretty sure there is a group buy on 17x9 +35 offset 5x100 RPF1's right now.
Ranatsu is offline   Reply With Quote
Old 12-05-2012, 03:43 PM   #3
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
This certainly sounds like a bad idea. I would imagine it could cause structural issues to the rim .... to have holes in locations that the manufacturer had not intended holes to be....
microbionic is offline   Reply With Quote
Old 12-05-2012, 03:49 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Rotiform and VR Wheels re-drill all the time, if you do it right it should be ok but still not something i would do unless it was impossible to get the wheel i wanted in the right bolt pattern. Even TireRack has 17x9 RPF1's so they aren't hard to get
JoeBoxer is offline   Reply With Quote
Old 12-05-2012, 04:35 PM   #5
wparsons
wparsons's Avatar
^^ Yeah, 17x9's are pretty easy to get anywhere. The only ones that are hard (or impossible) to find are the gunmetal wheels, but they're limited in any size/pattern.
flickr
Old 12-05-2012, 06:11 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Where are you guys finding 17x9 5x100 rpf1's on tirerack? The widest i could find for our pattern is 17x8.
Old 12-05-2012, 06:17 PM   #7
flatline
I'm seeing them...
Enkei RPF1 in Bright Silver
17x9
$257
(each)
Offset: 45mm
Backspacing: 6.73"
Bolt Pattern: 5-100
Rec. Tire Size:245/40-17
Weight: 15.9lbs.
$279 each for the black version
I doubt this will work, but try this link: http://www.tirerack.com/wheels/Wheel...int&tab=wheels
flatline is offline   Reply With Quote
Old 12-05-2012, 06:18 PM   #8
dabocx
dabocx's Avatar
Drives: Scion FRS
http://forums.nasioc.com/forums/forumdisplay.php?f=115
http://forums.nasioc.com/forums/forumdisplay.php?f=78
There was also a few vendors on here that would be able to get them for you.
dabocx is offline   Reply With Quote
Old 12-05-2012, 06:23 PM   #9
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Just went to Tire Rack's website. My BRZ is saved in my TR profile. Searched for available wheels. Enkei RPF1s showed up in 17x9 in black, silver, and gold. 45mm offset. All three colors in stock in 17x9.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 12-05-2012, 06:38 PM   #10
WolfsFang
Scrape Master
WolfsFang's Avatar
thats strange on the drop down menu it only goes to 17x8.
Old 12-05-2012, 06:53 PM   #11
JoeBoxer
JoeBoxer's Avatar
Change it to where you are viewing the wheels on your car?
Old 12-05-2012, 06:59 PM   #12
ST185RC
Drives: White Out FR-S
I'm not being an elitist or purist or snobbish (at least I'm trying very hard not to be) here but OP really should educate his friend so that he doesn't give out advice that can potentially kill someone if the wheel flies off from improperly drilling holes.
This goes for a lot of things that people ghetto out on. Cut springs for example. If you can do it in the most correct way, don't do it at all.
ST185RC is offline   Reply With Quote
Old 12-05-2012, 08:20 PM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Yea thats why I was asking. The moment he said it I was thinking would it affect the strength of the wheel.
Old 12-05-2012, 08:35 PM   #14
Miniata
Maybe an issue with your web browser? I just went back to the TR website, I put in 2013 FRS instead of BRZ, looked up wheels (by 17" and under 15 lbs) in both grid and vehicle view, and all three 17" sizes came up? Weird.
Drilling a Hole for Tow Hook or License Plate Hanakuso DIY (Do-It-Yourself) Guides 28 04-12-2019 06:02 PM
DIY: Center Mounting the Front License Plate WITHOUT DRILLING Neurytic DIY (Do-It-Yourself) Guides 28 05-14-2018 06:37 PM
Front bumper drilling/plates mooshoepork AUSTRALIA 5 11-18-2012 07:02 PM
I HATE @$$Holes! Kimsey47 BRZ First-Gen (2012+) — General Topics 40 06-18-2012 05:50 PM
