| Southwest AZ, NM, NV, OK, TX, UT |
Drives: 2013 FRS
Looking for a place to install lowering springs in DFW area
Anybody know a reputable shop to install lowering springs in DFW area.
Any recommendations? and expected cost? THX. |
Drives: 13 CSB BRZ Ltd
The only two shops I have used and personally trust would be Evolution Dynamics in Lewisville (the shop is owned by a mechanical engineer who used to work at Lockheed Martin), and Texas Track Works in Fort Worth. TTW specialize in suspension setups and have an on-site alignment rig.
-Acree |
Drives: 2013 SWP Subaru BRZ Premium
Do them yourself and save that cash, did my eibach prokit and theres good DIY on here. After, drive it a bit to see if you need an alignment, check for vibration, check if it pulls left or right and if no real problems then it'll be fine if you just daily drive. But if you track or drift your car an alignment is needed, but you'll also need camber bolts too.
Turbo FR-S
I would check with AWDTuning. They do great work
Drives: FRS Silver LS1 swapped.
SECOND ON AWDTUNING. Probably the cheapest as well.
Drives: 2013 FRS
Thank you guys for the recommendations. I will give them a call today.
considering RCE or swift springs. both will drop the car about an inch. is the camber bolt absolutely necessary for an inch drop? |
#7 | |
-Acree |
Drives: 2015 Subaru WRX
Hey I reminded my cousin about you. He said he's been busy working on other car. He said to call him again and he will let you know.
| Tags |
| install, lower, spring |
| Racecomp Engineering Yellow lowering springs install special! | Racecomp Engineering | Mid-Atlantic | 12 | 12-17-2015 02:34 PM |
| RS*R Lowering Springs Soon to be out! | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 01-16-2013 03:39 PM |
| SWIFT lowering springs ? | rikdrt1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 10-31-2012 07:15 PM |
| Lowering springs HELP | FRS_13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-27-2012 11:03 PM |
| Lowering springs? | Jeff Lange | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-11-2012 12:36 AM |
