Old 02-21-2013, 07:07 PM   #1
wWaldo
Drives: Asphalt Frs
Noob Question..
Ive ordered HSD coilovers, basically they make stance coilovers now my question is wdo I absolutely need cusco rear control arms?
Ive had a genesis coupe before on eibach lowering springs and didn't need to modify any other parts of my suspension?
I'm not really good with the suspension aspect.
wWaldo is offline   Reply With Quote
Old 02-21-2013, 07:12 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You won't absolutely need them, some people's rear camber is "ok" after the drop. If you want to be able to adjust it you will need either the Whiteline camber bushings or somebody's LCA, doesn't have to be Cusco there are other options on the market.
JoeBoxer is offline   Reply With Quote
Old 02-21-2013, 07:15 PM   #3
wWaldo
Drives: Asphalt Frs
I have 255/35/18 in rear and 225/40/18 in front.. Make a difference now?
Does it reduce the longetivity of the suspension?
what is the difference between the camber bushins and teh cusco rear control arms?
Old 02-21-2013, 07:21 PM   #4
JoeBoxer
JoeBoxer's Avatar
Tire size doesn't make any difference on the alignment unless it was something crazy.
The camber bushings are cheaper but more difficult to install and set up than the control arms. Whiteline has a control arm coming soon, Stance has some, I use SPC but there are others out too.
Old 02-21-2013, 07:23 PM   #5
wWaldo
Drives: Asphalt Frs
So technically whats the difference between the new ones and the stock ones? why must they be changed?
Old 02-21-2013, 08:15 PM   #6
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
The only reasons people will change them is to take some of the neg. camber out of the rear or simply for the bling factor.
GC_Adam is offline   Reply With Quote
Old 02-21-2013, 08:23 PM   #7
JoeBoxer
JoeBoxer's Avatar
To elaborate on this after a mild spring drop my camber was a full degree different from left to right. I wanted to be able to adjust it and the stock suspension has no camber adjustment.
Old 02-21-2013, 08:34 PM   #8
wWaldo
Drives: Asphalt Frs
Alright makes sense. I'll look into it , after i've installed the coilovers..
I'm guessing I'll need an alignment after 100Km on the coilovers? or when i get the control arm?
Old 02-21-2013, 08:59 PM   #9
JoeBoxer
JoeBoxer's Avatar
Both, align it after install and if the camber is too bad off order a set of control arms.
Old 02-21-2013, 09:04 PM   #10
wWaldo
Drives: Asphalt Frs
Kk thanks
Noob Air Filter Question GhostofAkina Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-09-2013 10:47 PM
Noob Dyno question bdanisi Engine, Exhaust, Transmission 2 02-04-2013 05:43 PM
Need clarification on a noob question. bdanisi Engine, Exhaust, Transmission 7 01-21-2013 09:44 PM
Noob lowering question. bazguitarman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-21-2012 04:53 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-03-2012 12:18 AM
