Old 03-25-2013, 01:34 AM   #1
ender2664
Drives: 2013 Scion FRS
Rotor Weight
I know what the stock rotors weight, but does anyone know how much the different aftermarket options wieght?
ender2664 is offline   Reply With Quote
Old 03-25-2013, 10:23 PM   #2
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Stock one-piece replacement rotors generally weigh about the same. If they don't, I would suspect they are of inferior quality. To really lose rotor weight, you need to go with a multi-piece rotor that has an aluminum hat. Something like these will save you a pound or two on the fronts and let you keep the stock brake setup.
http://frozenrotors.com/product/fron...pt+sti+models/
These may not be the correct rotors, but call them and they will be able to set you up.
http://www.racingbrake.com/Two-piece...exc-p/2042.htm
Generally the rears are tougher to loose weight on because they usually are all steel or iron because of the need to accommodate the drum shoes for the parking brake.
Old 03-25-2013, 10:39 PM   #3
ender2664
Thank you very much for the information.
Old 03-25-2013, 10:41 PM   #4
swift996
swift996's Avatar
I'm going with the Wilwood BBK for a WRX (just waiting on a few bolts). Check my journal for more details, but it shaves 16lbs per corner. I should have some more feedback soon.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-25-2013, 10:44 PM   #5
swift996
swift996's Avatar
I'm going to talk to Brady at Pure Performance (where I'm having them installed) and see if he is able to get any deal/offer this kit. It's essentially a WRX kit with 08+ brackets and BRZ bolts for the brackets. Want to have them on and working before selling the idea to anyone. These are only the 4pot version, but for about $1K it's much cheaper than the 6 pot kit. So it might be a good option for some.
Old 03-25-2013, 11:01 PM   #6
ender2664
How much was your willwood set up?
Old 03-25-2013, 11:07 PM   #7
msile
msile's Avatar
Drives: ISF
I installed the Wilwoods. Speed Factory has a thread on the weights. I think it was 8 pounds a corner less than stock. Front corner was 22.7 pounds.
Here is my thread:
http://www.ft86club.com/forums/showthread.php?t=29204
Here are SpeedFactory's threads (prices listed).
http://www.ft86club.com/forums/showt...hlight=wilwood
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 03-26-2013, 02:09 AM   #8
robispec
Drives: Black frs project
Our 4 corner brakeman kit Time attack rotors with e-brake delete saves 66 lbs off the car. These are designed for 3 fast laps put 2 lb / side heavier front rotors and you have a kit that will lap 30 minutes without any ducting. add heavier 3 lb/side fronts and 1 lb/side rears and you have a kit that will run all day long in traffic.
robispec is offline   Reply With Quote
Old 03-26-2013, 01:04 PM   #9
swift996
swift996's Avatar
I got it from a forum member who ordered it but wasn't able to use it per his class rules (SCCA/NASA). I'll update once I get them on. I got a little deal since "Scooby South" took a hit from what he paid. I'm guessing about $1K for everything.
- 12" Rotors
- 4 Pot Calipers
- Caliper Brackets/Bolts
- Stainless Brake Lines
I'd dub it the "Lite" kit for our cars. As I mentioned, I plan to talk with the Brady from Pure Performance to see if he is willing to offer them/can get a shop rate. I think for the price point they are a good option. I just happened to fall into them but I'm guessing these will fill my needs perfectly. I just don't want to jump the gun until they are on my car and show some gains. That's why I want to wait to talk w/ Brady as I'm sure he doesn't want to throw his name on something untested. I'm waiting on a few bolts to arrive but they should be here any day.
Old 03-26-2013, 04:37 PM   #10
ender2664
The reason I asked for rotor weight is because I am not about to drop 3-4 grand on a bbk, I don't need it.
Old 03-26-2013, 05:59 PM   #11
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
How much do the stock rotors weigh?
Apex Chase is offline   Reply With Quote
Old 03-26-2013, 07:12 PM   #12
ender2664
From the research that I have done:
Rear brake disc 13.2
front brake disc 17.0
Old 03-29-2013, 11:35 AM   #13
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
This sounds like a really interesting option. Please keep us posted. I'm all for dropping weight, 16 pounds a corner is huge. I just hope it performs well too but at such a large weight differential I wonder if this will hold up to 30 minute sessions at a HPDE or something along those lines?
industrial is offline   Reply With Quote
Old 03-29-2013, 12:12 PM   #14
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Rotors typically aren't the best place to save weight. Sure, it's less rotating mass. But rotors also act as thermal heat sinks (which is why they heat up). The less mass the rotors have (stay with the same material) the less thermal capacity they have and the quicker your calipers and brake fluid start to over heat.
Grimlock is offline   Reply With Quote
Noise from front calipers after pad/rotor install BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2013 01:48 PM
Turbo 4 rotor GS300 jschendel Other Vehicles & General Automotive Discussions 1 01-16-2013 08:15 PM
Sprint Rotor Temperatures Captain Snooze Tracking / Autocross / HPDE / Drifting 2 12-19-2012 01:59 PM
Power Slot vs Stoptech drilled rotor JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 10-19-2012 01:04 PM
Front Rotor Specs - Yes i searched. njccmd2002 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-03-2012 02:58 AM
