Old 04-02-2013, 02:00 PM   #1
DJCarbine
Thupercharged
DJCarbine's Avatar
Leaking water pump
When doing my header swap and bolting the aluminum skid plate back on, I noticed a bit of dried coolant on the block. I traced it up a few inches and it is coming from the water pump weep hole behind the pulley.
It was not wet, but it was dried/scaled coolant. At one point in time it was leaking, or it is currently leaking so slowly that the coolant is getting baked off the block before it actually drips down onto the ground.
I have 2K miles on the car and just noticed it. I would have never noticed it if I had not removed the skid plate and happened to glance at the waterpump.
If anyone else happens to have their skidplate off installing a header or doing anything else, take a quick look and see if your waterpump has the same coolant residue.
Old 04-02-2013, 02:22 PM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'll check mine this weekend when installing my headers.
Old 04-02-2013, 03:54 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
Do yourself a favor and check the header flanges with a straight edge to make sure they are not warped. I was chasing a leak for a while and it turned out my borla header flange was warped
Lots of wasted time under the car replacing gaskets and getting those skidplates on/off
Old 04-02-2013, 04:01 PM   #4
OrbitalEllipses
Drives: Attitude
Million Mile Warranty!
Old 04-02-2013, 04:21 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
Yeah but its almost not worth it to ship in your old header and get a new one and deal with waiting etc. I just knocked the high areas off with my mill and called it a day. Still think I have a leak somewhere, with my luck its a weld on the manifold and it needs to get sent back anyways.
Old 04-02-2013, 04:32 PM   #6
OrbitalEllipses
Drives: Attitude
And that's why I don't have any big brand products.
Old 04-02-2013, 05:21 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
In the defense of Borla, customer service is shipping me a new header once I email him my invoice from ft86speed factory.
Very good customer service.
Back on topic, I am very interested to see if anyone else has this coolant scale/gunk on their car. I will get a picture of mine when I reinstall my header
Old 04-02-2013, 08:20 PM   #8
Silver86
Silver86's Avatar
Drives: Argento FR-S
I thought I had this problem but it was actually that when the tech's replaced my fuelpump they didn't put the cap back on all the way.
Silver86 is offline   Reply With Quote
Old 04-02-2013, 09:18 PM   #9
Blue86
Drives: Sonic Blue 86GT Manual
Nothing as bad as a bit of flange that isn't quite right
Blue86 is offline   Reply With Quote
Old 04-03-2013, 11:54 PM   #10
fistpoint
Drives: Supercharged Golf Cart
You'd be surprised how quickly a good company can take care of a problem. They might overnight or next day the package, especially if you insist.
fistpoint is offline   Reply With Quote
Old 05-13-2014, 04:27 PM   #11
GT86_2014
Drives: Raven
I have same story - dried/scaled coolant after 1.8k miles!!!!!
it comes from weep hole...
is that normal?
did you change pump?
GT86_2014 is offline   Reply With Quote
Old 05-13-2014, 06:59 PM   #12
DJCarbine
Thupercharged
DJCarbine's Avatar
is that normal?
It's been fine since I noticed it, and that was around 13k miles ago. So hopefully it was nothing
2013 FRS
Vortech V3 11psi
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 08:14 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 08:57 AM
Water pump reliability - track use Kamran Tracking / Autocross / HPDE / Drifting 13 01-20-2013 11:30 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
