Old 05-02-2013, 10:54 PM   #1
normanb21
Drives: black frs
Autox alignment specs?
i just bought some camber crash bolts for the front end and hoping to get at least a degree of camber out of them. Also goin to get an alignment an I would like to know what the alignment specs should be for best performance. Toe? Caster? Camber?
normanb21 is offline   Reply With Quote
Old 05-02-2013, 11:59 PM   #2
TRev
After I get the Konis in this weekend and aligned on Monday my settings will be:
Max negative front camber
-.05 toe (out) front on each side
Factory rear camber (non-adjustable)
.1 toe (in) rear on each side
TRev is offline   Reply With Quote
Old 05-03-2013, 08:05 AM   #3
normanb21
Drives: black frs
Will the .1toe in affect the wear of the tire?
Old 05-03-2013, 11:11 AM   #4
TRev
I had .08 toe in each side on my Genesis Coupe and a set of RE-11's. After 7,000 spirited miles of driving and 150+ autox runs, the tires were still in the 1 to 2 32nd's range and wear was very even.
Old 05-03-2013, 11:49 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
0.1 total? no
Old 05-10-2013, 02:57 PM   #6
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
What do you guys think of these specs. I went .06 front toe out total and .06 rear toe in total.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-10-2013, 03:29 PM   #7
TRev
I basically have the same specs total (.06 out F, .08 in R) and really like it. As a daily driver, tire wear is a bit of a concern for me and with those settings really shouldn't be an issue.
Old 05-10-2013, 04:04 PM   #8
Tt3Sheppard
Sweet!
Firestone was able to give me these specs when finished:
LF Camber:-1.4
RF Camber:-1.4
LF Toe:-0.05
RF Toe:-0.03
LR Camber:-0.9
RR Camber:-1.3
LR Toe: 0.03
RR Toe: 0.01
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 05-13-2013, 01:19 PM   #9
kvnchu
Drives: 2005 S2000
Edit: NVM i must have selective reading, didnt realize was for autox
R-S3 235/45
LF Camber:-3.2
RF Camber:-3.2
LF Toe:0.00
RF Toe:0.00
LR Camber:-3.2
RR Camber:-3.2
LR Toe: -0.1
RR Toe: -0.1
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
Old 05-15-2013, 12:32 PM   #10
Turn in Concepts
Turn in Concepts's Avatar
R-S3 235/45
LF Camber:-3.2
RF Camber:-3.2
LF Toe:0.00
RF Toe:0.00
LR Camber:-3.2
RR Camber:-3.2
LR Toe: -0.1
RR Toe: -0.1
Interesting to see so much rear camber. I find that I like about a degree less in the rear than the front on these cars although I have not tried running more rear camber with without toe in.
Tony
Turn in Concepts is offline   Reply With Quote
Old 05-15-2013, 01:05 PM   #11
kvnchu
Drives: 2005 S2000
Hi Tony,
Well i think the R-S3 does better with more camber. Rear, im up to perfectly up to the wear bar and the fronts i've worn into that little triangle.
I was thinking of increasing the fronts as well for this but the car is handling fine and I'll be going to Rivals for my next set so i'll probably have to dial it back down.
Best,
Kevin
Old 05-17-2013, 11:44 PM   #12
normanb21
Drives: black frs
What about caster?
Old 05-28-2013, 12:41 PM   #13
warman
warman's Avatar
Drives: WRB BRZ
What's the function of the toe in for the rear? I understand toe-out in the front should help turn-in some by building a small slip angle prior to the turn, and the rear in is supposed to keep the car stable under braking, but how does it do that?
I currently have a stock car with the SPC camber bolts, -2.2 degree camber up front and 0 toe front and rear. I'm getting Koni's and a Stranoparts bar next and I was debating if I should mess with the alignment settings.
warman is offline   Reply With Quote
Old 05-28-2013, 01:05 PM   #14
TRev
Hopefully this info will help:
"With the steering wheel centered, toe-in causes the wheels to tend to roll along paths that intersect each other. Under this condition, the wheels are at odds with each other, and no turn results.
When the wheel on one side of the car encounters a disturbance, that wheel is pulled rearward about its steering axis. This action also pulls the other wheel in the same steering direction. If it's a minor disturbance, the disturbed wheel will steer only a small amount, perhaps so that it's rolling straight ahead instead of toed-in slightly. But note that with this slight steering input, the rolling paths of the wheels still don't describe a turn. The wheels have absorbed the irregularity without significantly changing the direction of the vehicle. In this way, toe-in enhances straight-line stability." -Smithees Race Car Technologies
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
alignment dori. NY / NJ / CT / PA 10 04-02-2013 04:57 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 11:16 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 10:33 AM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 07:31 PM
