Swapping brake fluid
Im going to be upgrading my brake package soon (rotors, pads, lines and fluid).
My friend who is doing this install for me has asked me to find out if there is anything in particular to the fluid swapping process that he should be aware of (e.i. abs sensors need reseting, something like that). Hes a pretty darn good mechanic I just want to do a little follow up for him before he gets to it. Can anyone direct me to someone whose done a DIY on this? Any suggestions from those who have done this already? Any info would be much appreciated. |
Drives: '13 BRZ / '11 Outback / '06 Tundra
Nothing extra.
Drives: 2013 Subaru SWP BRZ Limited 6AT
Since it's your friend doing the job for you, I'd say a 12 pack is the only part you should add to the normal procedure. :happy0180:
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
Nothing unusual... same as any other car
Ok, he said hes had some goofy stuff happen while doing the fluid for a 97 camaro a while back so hes leery about it. (something about not getting fluid to the rear brakes and some abs sensor issue). Just tryin to put his mind at easy about it since I have heard nothing bad about it so far. Like I said before, hes a good mechanic, I just want to provide him with all the information I can since hes never worked on an FR-S before, thanks!
It's already covered, but there are no surprises. A bonus is that the clutch has its own reservoir so you don't have to flush/bleed the clutch line at the same time.
| Cooked my brake fluid!!! | markitect | Tracking / Autocross / HPDE / Drifting | 18 | 07-11-2013 11:53 AM |
| Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-14-2013 12:46 AM |
| Brake fluid leak.. | tintumz22 | Issues | Warranty | Recalls / TSB | 9 | 02-01-2013 04:20 PM |
| $98 Brake Fluid Upgrade | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 15 | 10-22-2012 03:50 AM |
| Brake fluid volume | celica73 | Tracking / Autocross / HPDE / Drifting | 1 | 08-20-2012 03:05 PM |
