8SiX
Drives: FRS 10series
Lowering car with springs... What else do I need?
I've got some RS*R springs waiting to go on the car. These springs lower just about an inch. What else do I need to correct the alignment?
So far the only thing I've read on my searches are front camber bolts. Do I need something in the rear to correct camber? Thanks all. Hopefully the ride quality is good enough for me to run this setup. I don't want to have to go to coil overs if I don't have to spend the money. |
Drives: '13 DGM BRZ Limited
See this post: http://www.ft86club.com/forums/showthread.php?t=44366
8SiX
Wow. Replacing rear lca seems extreme to get camber. Why does this seem to be the preferred method of adjusting rear camber when there are uca bushings?
Drives: Silver 2013 BRZ limited
8SiX
I'm hoping there are some affordable lca out there that doesn't mess too much with the geometry.
Ok. So I buy me some camber bolts up front and some lca for the rear. Then I install that crap with my springs and ill be able to realign my car? Thanks for the help. |
#6 | |
I bought the new spc lca which is like 200$. Bolts is like 30$ Then get it aligned |
Drives: 2013 Firestorm FRS
Do you need the LCA's if you are getting coilovers ?
well that sucks.
#10 |
Custom User Title
Drives: Asphalt FR-S MT
You are only dropping an inch. You don't really need camber correction.
#11 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
offtopic, but i'm curious where you got your RS*R's from? I'm debating between H&R super sports or RS*R super downs.
SC10N FR-S #435 of 2500
#12 |
8SiX
Contact RS*R directly. Find their USA web site, find their contact email and ask to buy. They are really fast.
#13 |
Drives: 2012 Toyota 86
i have the rs*r super downs and am very pleased with them. they drop the rear about 5mm more than the front and it really helped with traction out of the turns.
#14 |
Just a dude
Drives: Scion FR-S 2013
Disagree. Mine was funky till I put in UCA bushings moving forward ill do lca when go coils. Better camber and alignment is a world of difference how this car handles IMO.
| WTS H&R Lowering Springs (Never used) | g0ast | Brakes, Suspension, Chassis | 3 | 05-21-2013 12:34 PM |
| TRD Lowering Springs? | kALMIGHTY | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-29-2013 11:10 AM |
| For those with lowering springs. | wawro569 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-10-2013 02:36 PM |
| Lowering springs HELP | FRS_13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-27-2012 11:03 PM |
| Lowering springs? | Jeff Lange | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-11-2012 12:36 AM |
