Old 08-29-2013, 09:30 AM   #1
charged86
charged86's Avatar
DIY clamping the evap vacum ports under the manifold!!
This DIY is for boosted people especially ones over 9 PSI, VORTECH USERS must take special care when removing the AC compressor which is optional
On mine for ample room I remove the upper charge pipe and the throttle body. And the ac compressor!!
1.) Remove upper pipe and throttle body.
2.) Under throttle body, look underneath and towards the pass fender
You will find this vacum egr port coming out of the manifold clamp there!Note: this is the one everyone forgets
3.) On the back side of the manifold driver side is the 10mm nut that bolts
The evap solenoid to the manifold. Remove nut Hopefully you have self ratcheting wrench
4.) Optional step removing AC Compressor for turbo guy should be a
walk in the park remove 3 14mm bolts lay compressor to the side also remove accessory belt.
VORTECH USERS SEE BELOW
5). Pull on the hose coming off the port (the one we clamped)
6.) Clamp the hose on the evap solenoid and I believe there is another hose
Coming of solenoid going to fuel pressure regulator clamp that too.
Vortech users attention! if you chose to remove ac compressor which I chose to do. The compressor will come out when you tug on it. Putting it back in is a total pain in the scotum. The compressor must be pushed back into place with the 2 14mm mounting holes being the biggest issue to line up. use a short Phillips head to pre align holes before attempting to thread bolts use anal lube on bolts to counter the affect of cross threading which is as bad as getting your prince albert piercing stuck in your zipper. it was pretty difficult but it is possible.
picture is courtesy of @Dezoris my long time intimate friend
edit: I have the egr labeled. it is not, its the evap sensor solenoid
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-29-2013, 10:00 AM   #2
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
What is the reason for doing this?
ahaghshenas is offline   Reply With Quote
Old 08-29-2013, 10:20 AM   #3
Dan@AWD
Drives: 2013 Argento FR-S
Creates a boost leak when they pop off under boost.
Dan@AWD is offline   Reply With Quote
Old 08-29-2013, 10:28 AM   #4
ahaghshenas
Drives: Subaru BRZ
Is this the solenoid that has the blue plug and you can install a ebcs in its place and manage boost via ECUTek?
Old 08-29-2013, 11:15 AM   #5
charged86
charged86's Avatar
sounds about right I just looked I don't see a blue harness but if you vacumed teed it at the throttle body that would be a good source.
Old 09-09-2013, 12:01 AM   #6
mad_sb
Drives: 2013 Asphalt FR-S
Fairly sure that is the evap solenoid not an egr solenoid. Thank you for posting the pic!
Old 09-10-2013, 05:39 PM   #7
charged86
charged86's Avatar
lol your probably right its dezoris's pic I edited it your right its definitely not the egr wow that was really noob of me dammit
Old 09-17-2013, 11:11 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Something that we dont need
I removed it
Sent from my iPhone using Tapatalk - now Free
Old 04-08-2015, 09:38 AM   #9
IBill4You
Drives: 2015 Subaru BRZ
Are we using 9/16th hose clamps for these?
IBill4You is offline   Reply With Quote
Old 04-08-2015, 07:56 PM   #10
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Yes. The big one under the Throttle body is difficult to fit the clamp on, but it does fit.
JimmyMac is offline   Reply With Quote
Turbo Manifold Admired Forced Induction 1 08-26-2013 01:19 AM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
Manifold nut size Bullnettles Engine, Exhaust, Transmission 5 06-11-2013 01:02 PM
Power Ports/ Cigarette Lighter Issues Tanuki Issues | Warranty | Recalls / TSB 6 11-21-2012 05:59 PM
FRS en route to Japanese ports. ayau FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-13-2012 07:28 AM
