Old 09-25-2013, 05:58 AM   #1
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Rearview camera without drilling holes
Got this camera:
And installed it where the key barrel used to be.
This camera is very small and is hardly noticeable:
Works great at night.
The camera came with a long enough RCA cable included so all it cost me was $20 plus some electrical wire and easy splice clips. Very happy with the result.
Thanks to @Ryan86 for finding this camera in the first place.
Updated eBay link:
https://www.ebay.com/itm/170-HD-CMOS...AAAOSwGTRdnYcm
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 09-25-2013, 07:08 AM   #2
Sporran
Drives: Metallic Grey 86
Looks good Sav. How easy was it to install - do you have to remove any of the panels other than the inside trim?
Sporran is offline   Reply With Quote
Old 09-25-2013, 07:16 AM   #3
sav
sav's Avatar
Thanks. It took some time but was easy enough.
Removed the plastic piece as pictured above to fit the camera as well as the boot trim on the left hand side and the one panel by the left hand side door to run the wires through. Power for the camera as well as head unit reverse trigger wires are fed from the reverse light.
There are 2 wires running to the radio - trigger wire and RCA.
95RON SAV Tuned
Old 09-25-2013, 07:30 AM   #4
Sporran
That doesn't sound too problematic - will need to check out how the plastic piece comes off though. One other question regarding the head unit trigger wire if you don't mind - doesn't the existing wiring harness contain a trigger wire to avoid the need to run one from the boot or were you able to tap into a reverse feed near the HU itself?
Old 09-25-2013, 08:59 AM   #5
sav
sav's Avatar
I've also read about the existing harness but when testing with a multimeter it didn't look like it was working. Might be different on the FR-S so worth trying that first.
95RON SAV Tuned
Old 09-25-2013, 09:42 AM   #6
Sporran
Ok, I'll bear that in mind. Thanks for the info
Old 09-25-2013, 10:04 AM   #7
sav
sav's Avatar
No problem at all. Shout if you need any advice.
The panels are really easy to remove, the one by the door simply pops out. The piece on the boot uses 8mm nuts, just be careful not to drop them into the boot.
95RON SAV Tuned
Old 09-25-2013, 02:34 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
Do the stock head units (for the BRZ) have the IO to plug one of these in without modification?
Old 09-26-2013, 02:59 PM   #9
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
What did you do with the key barrel? Just remove it and rely on the remote?
DoomsdayJesus is offline   Reply With Quote
Old 09-26-2013, 03:20 PM   #10
sav
sav's Avatar
Yep, removed it and sealed the hole after pulling the camera's wires through.
I've never used or needed a key to open the trunk on any car I've owned over the last 10 years so I doubt it'll ever be a problem.
95RON SAV Tuned
Old 09-26-2013, 09:59 PM   #11
foglesre
Drives: BRZ Limited
I didn't know it had a keyed lock...
foglesre is offline   Reply With Quote
Old 09-27-2013, 05:06 AM   #12
sav
sav's Avatar
Exactly, you don't need it. With a license plate your key probably wouldn't fit anyway unless you've got keyless entry in which case the tiny pull out key fits fine.
95RON SAV Tuned
Old 09-30-2013, 03:31 AM   #13
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Best camera for its price.
Nice job there Sav
Ryan86 is offline   Reply With Quote
Old 09-30-2013, 05:43 PM   #14
chjno86
a/k/a ikuzOtaku
chjno86's Avatar
Drives: Whiteout FRancheSka
Anybody with an frs tried this yet?
instagram.com/chjno86 __ #TEAMFRANCHESKA _ #SOCALVALLEY86
chjno86 is offline   Reply With Quote
Question on drilling new holes WolfsFang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-06-2012 09:02 AM
Front bumper drilling/plates mooshoepork AUSTRALIA 5 11-18-2012 07:02 PM
