Old 12-14-2013, 07:54 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation DIY Thread on Installing a Front Lip ? Particularly the Downforce CF Front Lip
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 12-16-2013, 10:26 PM   #2
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
its pretty easy use 3m tape and some push in plastic panel plugs. thats how I installed mine. took 20 min
Liquid6 is offline   Reply With Quote
Old 12-17-2013, 08:16 AM   #3
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Mmm i would not recommand that...
I've got the downforce lip and I've lost one on the road.
I've use screw attach, screw and double face tape and at a certain speed the bumper hole snapped and the lip touched the ground.
I don't have any picture of my installation but I'll try to give you some advice.
For the double face tape, you will see close to the visible portion their is a little slot all the lenght of the lip. This is made for double face tape. Find the right dimention tape, and apply it there.
For the screw, it may seem a little bit overkill but it's solid.
I've put some metal plate about 5" long, drill a hole in the middle and weld a nut on it. I've put it IN the bumper and bolted the lip on the bumper.
So the plate "sandwish" the bumper and the lip together for a really strong fit.
You could use some nut and washer too, but will require bumper removal for installation.
Hope you will understand me since my english is not perfect!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 12-17-2013, 05:28 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I installed my front PU lip from Bayson R without removing the front bumper.
I utilizes self tapping screws as well as nuts, bolts, and washers. You need to make sure that it does not fall off when driving as it would present a hazard to yourself and other drivers. I suggest using something more resilient than tape and plastic tabs.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 12-17-2013, 06:48 PM   #5
BRAWL
Drives: Toyota 86 GTS Velocity Orange
I put mine on with all the bolts and nuts under the front bumper. was a bit of fiddle, but then I didn't raise the car or remove the stone guard (only pushed it aside a bit)
BRAWL is offline   Reply With Quote
Old 12-19-2013, 01:35 PM   #6
ScionFR-S
ScionFR-S's Avatar
is this video similar to what you did ? and does the lip come with instructions ? [ame="http://www.youtube.com/watch?v=EEOCncqEdp4"]HT Autos Front Lip Spoiler - Unboxing, Install and Review - 2013 Subaru BRZ - YouTube[/ame]
Old 12-19-2013, 01:53 PM   #7
trueno86power
[||•]=(86)=[•||]
Hum no. It's way more solid than that.
The lip come with NO instruction or hardware.
If my car was not in winter storage I could take some pic but I can't
The lip have six hole and they are aligned with the 6 hole on the bumper. These hose have noting clipped or screwed.
Like I've told, I've made some metal plate with a nut welded at the middle for each hole.(6). And I've put those plate inside the bumper. After that I've bring the lip and screwed the bolts so the plate sandwish the bumper and the lip together.
Sorry for my crappy english.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 12-22-2013, 02:25 PM   #8
ScionFR-S
ScionFR-S's Avatar
okay so maybe some 3M tape with 6 screws and washers should be enough?
Old 12-22-2013, 03:55 PM   #9
trueno86power
[||•]=(86)=[•||]
Should be enought!
Envoyé de mon ST18a en utilisant Tapatalk
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 12-22-2013, 09:16 PM   #10
ScionFR-S
ScionFR-S's Avatar
Should be enought!
and did you drill into the bumper to make new holes ? or did you use the holes in the bumper already ?
Old 12-22-2013, 09:22 PM   #11
trueno86power
[||•]=(86)=[•||]
Ive use the existing hole!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Installing front pipe...need gasket sealant? Fizz Engine, Exhaust, Transmission 10 07-23-2014 11:40 AM
Downforce FRP front lip version NoFear99 Cosmetic Modification (Interior/Exterior/Lighting) 24 03-02-2014 09:41 AM
shop/local installing MXP exhaust catback & front pipe jgonx213 Southern California 7 11-06-2013 03:55 AM
Do I need to use a torque wrench when installing Grimmspeed front license kit? Meanderchap Cosmetic Modification (Interior/Exterior/Lighting) 3 06-01-2013 08:09 PM
Help installing AP front pipe... S1000rr Engine, Exhaust, Transmission 6 12-28-2012 11:10 PM
