Drives: AE86, 2x GT86, TE27
Custom subframe
Had the car up on the hoist getting a few things done today.
One thing we wanted to look at was correcting the rear roll centre. It didn't take my fabricator long to decide that it would be best to make a new subframe with multiple arm mount options for correcting roll centre / suspension geometry. He also mentioned about solid mounting the frame to the car, and using more generic nolothane bushings rather than application specific ones we are governed to use at the moment. There'll also be a tidy weight saving. My subframe will be coming off in the coming weeks to make a jig. Anyone interested in getting one made up as well, flick me a PM or mention something here. This is a fairly serious part, but a worthwhile investment for track guys. At a guess, I'd expect the price to be in the $4k region. |
AutoX-10/10ths every run
Beyond my price range but VERY interested to see what you come up with. Good luck and please post lots of photos.
Drives: Subaru BRZ Sport Tech Satin White
I'd be interested in knowing what changes are being contemplated to the rear roll centre.
Making it higher or lower? |
#4 | |
So as you lower the car, and the control arms move away from their ideal angle, you'd move the control arms up a notch or two on the subframe to put them back at a more ideal angle. |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I just found the thread I was telling you about earlier. Here it is: http://www.ft86club.com/forums/showthread.php?t=48157
Weight Nazi
So, the ability to restore the roll height to factory spec after lowering the car, at least relatively to the new ride height. Not to adjust the effective roll center to a different height.
#8 | |
You'll be able to adjust them without lowering. It'll just be in increments. |
Drives: FR-S Whiteout
I'm assuming you guys have seen this before.
![]() ![]() ![]() ![]() Good as a reference for your welder. |
#10 | |
Because compromise ®
Drives: Red Herring
(I have to hide my wallet when I see stuff like this.)
#11 |
That Guy
Drives: 2013 asphalt FRS MT
Did you also notice the nameless oil cooler with hard lines, oh and the turbo kit they made for it to?
#12 |
Drives: Red Herring
Also "meless" on the hoist arm.
#13 |
Vtec Jesus
WAT!
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
| HELP i think i cross threaded subframe mounts | autoCAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 03-11-2025 01:01 AM |
| Whiteline rear subframe bushing install... | fl_speed001 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-11-2020 01:29 AM |
| whiteline rear subframe inserts | charged86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-18-2013 10:20 PM |
| Subframe/Drivetrain Thoughts.... | TrackDog | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-10-2011 11:53 PM |
