Long tube catted headers possible?
I know this is pretty much impossible to do with good length on the primaries, good spacing between the collector and cat and keeping the OP flange in the stock position, but is it possible to do if a different length OP was made to match?
I haven't looked that closely under the car to see how much space there is around the OP, but maybe there's room? Not sure how much of a market there would be for this either? I might be in the minority that wants to keep two cats?
Drives: 1980 corvette, 2014 Subaru BRZ
long tube is what nameless(maybe a few others) are doing, or the closest thing we will see with this engine. They put the extra tube in front of the belts instead the classic v8 design where it goes down the side of the car. I am guessing for space reasons. there was talk about the nice(high flow) cats would not hold up that close to the engine due to heat they would die too quickly to be worth it. I do not think anyone wants to put a standard cat in their header because it would cut down on the dyno.
The reason nameless isn't running a cat is there's no room for it with proper length primaries, not because the cat would suffer from the heat. EGT's are MUCH hotter than ambient under hood temperature, so it doesn't matter if the cat is touching the block or two feet away.
Drives: 2013 Subaru BRZ & 99' Ford Explorer
long tubes would be nice.
Some say.....
Drives: 2007 Subaru Impreza 2.5i
I'm waiting to see what JDL has up their sleeves. They have a catted EL coming soon: http://www.ft86club.com/forums/showt...6&postcount=10
Plus, they just released pics of their V3 EL. Curious to see if the two will have anything to do with each other: http://www.ft86club.com/forums/showt...&postcount=106 |
#6 | |
~Namaste~ |
FA20club are most definitely not long tubes. The primaries aren't anywhere near as long as on the nameless. All the extra length is after the collector.
I haven't looked at nameless, p&l or fa20club headers up close, but I would bet the primaries on the nameless are almost twice as long as the p&l and fa20club.
| Catted Headers | EN2_Squirrel | Engine, Exhaust, Transmission | 53 | 12-16-2016 10:52 PM |
| catted headers for a Perrin header back exhaust | skye67 | Engine, Exhaust, Transmission | 6 | 08-18-2013 11:22 PM |
| So any chance for catted UEL Headers? | Flasher | Engine, Exhaust, Transmission | 20 | 07-01-2013 12:51 PM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 01:29 PM |
